Old 07-18-2008, 01:16 PM
Brian jones Brian jones is offline
Default Correct gasket and hangers
What is the correct gasket for a stock 64 gto exhaust pipe to manifold flange. Would it be the compressed round "doughnut" type or is it a flat metalized type gasket.
Also were can I get new rear tail pipe hangers. The ones that bolt to the outside of the rear frame rails?
Thanks,
Brian
Old 07-18-2008, 02:19 PM
engineer engineer is offline
look at the vendor catalogs for the hangers. There are no gaskets on pontiac head pipes unless there was a removable heat riser valve like on later models.
