zinc additive for oil
Does anyone put a zinc additive in their oil?
Let me know what you put in your car. I have a 389 tri-power. thanks, FB66 |
ZDDPlus is a good choice, PY offers them for $10.00 per bottle. The part # is RPZ163.
Supposedly even GM's famed "EOS" break-in additive has been discontinued because it had zinc. So we had to buy a can of "MOA" from BG Products to break in the new cam & lifters in my nephews car. It was $7.49 for an 11 ounce can. Can find at: www.bgprod.com. |
Why mess around with additives when certain synthetic oils like AMSoil has high zinc levels?
My apologies to those who have had negative experiences with AMSoil. |
GMpartsdirect.com still offers the GM EOS.......Part #88862586
http://gmpartsdirect.com/results.cfm...partnumber=EOS |
GM E.O.S. is available where i live . Amsoil is too expensive $80.00 just for oil . When i was in Florida in February i picked up Mobil 1 15/50 $20.00 2 large jugs and 2 quarts, to do the GTO and Olds. I have used that for years with no issues and have not added any zinc additive to either engine. Both cars have 60psi pressure at cruise speed. I will be picking up more Mobil 1 15/50 when i go to Syracuse next week . I just wish they would sell it here again .
Scott
Scott If you always do what you always did You always get what you always got |
Yes....always have...GM EOS is what I use.. Briefly discontinued early this year, production has been reinstated with a different part number. Zinc and Phosphate contents are the same though. As "abefroman" stated the new part number is 88862586..
Jeff |
I don't think it has much as it used to. How could anyone have a problem with the best product on the market?
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
EOS every oil change
Rotella has zinc, I use it. Also for the first 2 oil changes in my new motor I added a bottle of GM EOS
Can do the talk, can't do the walk......therefore need deep pockets Injection is nice but I rather be blown If you got it flaunt it, if not fake it (Snoopy) Original 1977 Firebird / Welded tube frame connectors TH350 with shift kit / 400 bored/stroked to 455 by PDude OCD=Waxing and polishing your oil filter SICK=wetsanding your exhaust pipe |
Rotella + Crane cams break in lube supplement
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
I have read that Rotella oil still has approx 1200 ppm of ZDDP in it,down from about 1400 ppm,still enough to provide protection in a flat tappet cam motor.If you can find an MSDS on line or somewhere else,I would think they would by law,have to list the amount of ZDDP it contains.The company has also stated that they have no plans to further reduce the zinc content,according to what I read.(magazine article)
http://www.gmpartsdirect.com/ search part number 88862586 ... Also local dealers in my area have it but it is a hell of alot more expensive ( $22 per )
Jeff |
Is Rotella oil made for desiel trucks? I was reading the back of the bottle, and it said it was for desiels? Is this right? Can you run it in your car?
Help me out. Can you buy Rotella at Walmart? fb66 It was w40-15 weight. |
Yes,thats right, it was originally designed for deisels.Big rigs are going to catalytic converters,thats why Rotella has cut back on the zinc level(according to what I read)There's no reason why it won't provide satisfactory lubrication in a flat tappet motor,just because it was designed for deisels.I used it for break-in on my 400,and my son is running it in his big-block chevy with good results.We also add an oil supplement at each change for an extra margin of safety.I believe rotella is available at wal-mart.Use the 15-W30if its available,15-40 being the second choice.
Most of the cam companies have a break in additive. If you install their cam and don't use it,there is no warranty. Check out cam companies websites under warranty.
We use Rotella and a bottle of additive from comp cam or whatever cam company the cam comes from. Also put another bottle in at oil change like they tell you.
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
Anybody ever use ZMAX at break in?
1. Some--but not all--"Diesel" oils are in fact DUAL RATED; Diesel and gasoline. Look on the back at the starburst. IF it has Compression-ignition and Spark ignition ratings--it's fine for your gasoline engine. (so, for example CJ and SF ratings)
2. Do you have stiff enough valvesprings to need more high pressure additive than is already in Rotella and other dual-rated oils? 3. Nobody is "eliminating" the high pressure additives; but they are being reduced some. If the cam is already broken in; and the valve springs are stock-to-mild performance--good chance you don't need additives. |
