Brake Controller
I found my trailer finally. I bought a used 2007 20' car hauler with single axle electric brakes. Now I need a brake controller. I have a 2000 Chevy Silverado 2500. It's pre-wired for a brake controller.
What type/brand is recommended? I see there are timing, inertia, proportional, hydraulic over electric, etc. What's best/necessary? |
Tekonsha Prodigy. I use one in my truck. Set it up one time and leave it alone.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
I have a similar rig and use a Tekonsha Prodigy brake controller - more expensive than the $50 POS autozone special it replaced, but well worth it.
Yep, another vote for the Prodigy. I set mine up in 5 minutes and in 20' of driveway.
+5 for Prodigy, and I pull a 10K lb enclosed trailer. Works like a charm.
Another vote for Prodigy. 20ft open, dual brakes. Easily adjustable, breeze to use.
I guess your question has been answered..
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
I'll say! Case closed! Thanks!
Ok, since we've answered the controller question...
...let's talk about the trailer for a minute: Open or enclosed trailer? What do you mean when you say the truck is "prewired"? Do you mean you have the jumper harness that plugs into the "LH BEC" (aka the fuse block under the dash)? I might be able to help if you have questions about wiring the truck. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Yes, it has the factory jumper harness. I already figured out where the harness and fuse plug in. I don't anticipate any problems wiring it up. I'll remember your offer though. Thanks. |
i used prodigy on that size trailer, it was great.
also- it's been a couple years, but as i recall, there is a fuse that will need to be inserted to get power to your trailer and recharge the brakes battery. if this is your first time hooking up the 7-pin harness, look out for it. the factory ships trucks without the fuse installed (a dummy fuse in its place), and sometimes it comes in the glove box when the truck was new. iirc, it's a 40 amp maxi fuse. ** edited to add: the fuse is 40amp, located in a slot labeled 'Stud #1' under the hood on driver's side under a plastic cover. comes with dummy fuse in there. Last edited by TheMonkey; 06-12-2008 at 02:49 PM. |
One more thing, if your truck has a trailer tow package, Tekonsha makes a harness for it and it's a plug and play deal for most applications.
I have an almost new Tekonsha controller I'd like to sell. I'm not sure if it's the "Prodigy" model but I could check tonight. My new Chevy came with an in-the-dash controller so I didn't need it. This one was mounted in my wife's Durango which I only towed with 2 or 3 times. Let me know if interested - I have the box, instructions and all hardware - $40.00 plus ship.
Mark O.
Ain't as good as I once was, but I'm as good once as I ever was. |
Another way to tell is the correct "2002 & earlier" harness will have a brown plug; "2003 & later" harness will have a white plug. K
be careful of clowns like me that modified the white plug to behave like the brown plug
You're not a clown. I've modified almost everything I own. |
You guys are good. I have the 2002 2500HD and went through all of what was described here. I too have the Prodigy and its awesome.
One thing though...you may not run into it, and your trailer might do it differently (Ive got an 15ft Econo-trailer) but I had it plugged into the truck harness but didnt have it on the ball (didnt have the receiver at the time) Didnt think it mattered, but the controller wouldn't see the trailer as "connected" until it was on the ball. Borrowed a friends receiver, and bam...all was good once the trailer was actually on there. not sure why exactly, but I imagine it must ground through that connection somewhere. My $.02.
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well. >>My 73 Build thread |
