Door lock rod holders
Does anyone know where I can get these? The are the plastic channels that clip to the inside of the door that hold the lock rod.
I am trying to post a pic but it keeps failing. So here is a link to my kodak gallery. http://www.kodakgallery.com/I.jsp?c=...localeid=en_US Pics 2 3 & 4 I thought PY had them under item RPI327 the description matched, but the item I got wasnt even close.
Mike 1970 LeMans Sport Convertible www.fquick.com/mikecio1 http://www.facebook.com/MikeCio1 Last edited by MikeCio1; 06-05-2008 at 03:54 PM. |
If you are referring to those little white plastic deals I think they are being reproduced now. I saw them in the new Original Parts Group catalog (C240479). I'm sure the other vendors have them too.
Mike 1970 LeMans Sport Convertible www.fquick.com/mikecio1 http://www.facebook.com/MikeCio1 |
Mike, do you have a picture of what you received? I agree, from the description, RPI327 should have been a match. Ames PN is F109 for a similar description (no picture, though). I'll look at my doors to see if they match yours.
Mike,
I've probably got a few of these lock rod setups laying around. I didn't think you could replace the plastic, aren't the rods bent after the plastic slides are installed? Been awhile since I looked at them. do you need both sides or just one lock rod setup? Later, Dennis |
I would think they would come out with a replacment clip since they get brittle after 30+ years. PM me if you have something that will work.
I've got a few...
entire mechanisms if you need them. Doesn't look to me as if the clips can be removed. Ron
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Your right about the clips not being able to be removed I was just hoping they had an aftermarket solution. The part PY sent me is about a tri angle shaped piece of plastic an inch long 1/2 inch wide flat with a circular indent on the point end and a square indent on the wide end. I wwill try to post a pic but my cam wont load.
