Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Advice? 15hp Devilbliss
I have been in the market for a good air compressor for my shop that will handle sandblasting painting etc... Unfortunately I have champagne tastes and a beer budget. My allowance is around 500 bucks. I have permission from the wifey and its either use it or lose it if'n ya know what I mean. I might be able to add a little bit more to the 5 but shhhh... don't tell my wife I've been hoarding.
There is a guy selling a 15 hp Devil-bliss air compressor. I do not know if it is vertical, horizontal, CFM's, tank size, age, nothing else. He said it was working in his old shop, he moved and now has a little shop that has no 220 service. He really does not know anything else about it not even the model number. He did say it would take 3 people to load it so it must be a large one. I am assuming a 15 hp would have more than enough power to handle anything I can throw at it. And Devil-bliss is a pretty standard name isn't it? He only wants 400 for it which would leave me 100 for new filters regulators whatever else I might need. Anything in particular I should check when I look at it tomorrow? Is a used one like this a bad idea? Do you know of a new one that will work for me? I would think this being memorial day I might could find some good deals but everything that has interested me is 800 plus. Whatcha think?
Wayne |
It is aprox 3 foot high and 4 foot long. Does not sound very big to me. Perhaps he is wrong about the hp.
Wayne |
Just stopped at Lowes. I have a $75.00 off card for them. What do you think about these...
Kobalt 80gal, 155psi, 4.5hp, 14 @ 90, 16 @ 40 $699.00 Has regulator 2 hookups guages etc mounted in a nice neat fashion. 3 small cylinders on pump. Plug N Play. Cambel Hausfeld 80gal, 140psi, 5hp, 16 @ 90 $649.00 Has simple regulator and thats all, must buy and install everything else. 2 large cylinders on pumps. Not so plug N play. Still waiting for a call from the guy with the 15hp. Need info on what to look for.
Wayne |
If it is a 15hp motor, it'll almost certainly require a three phase electric service. You'll rarely find a single phase electric motor bigger than about 7 1/2 hp.
As you probably know, the capacity of the compressor in CFM is going to be the big thing if you want to use it for sandblasting. |
Ok here is what I have found out...
Devilbliss 330 model Single stage Cast Iron dual belt 150 psi I'm googling it now but any thoughts on it? He is concerned it might be to large for me, is that possible?
Wayne |
When it comes to air compressors, I'd rather have too much than too little. Sandblasting and air tools really eat up the air quickly.
If it ain't broke, fix it 'till it is |
Geesh, no luck finding any info on the used one via google. Surely someone here knows about it.
Wayne |
I looked at the Devilbiss website and didn't find any new compressors that had that model number. Is this a pretty old machine?
I'd wonder about a 15hp compressor being only a single stage. Have the guy look at the motor, there should be a nameplate on it that tells the voltage, amps, hp, etc. |
Check out the specs. closer like Stuart said. Odds are it will pull a lot of amps. Don't exceed the capacity of your box/breaker.
yeah it's an old one. Evidently it can be switched to 110 but he doesn't know how. He was supposed to call me back this afternoon but hasn't. Maybe tomorrow.
Wayne |
wow, all this research will wear you out.
Anyone care to give thoughts on this one? Rockworth 2 stage compressor $750 Iron sleeve though. Is that really a terrible thing? HP (Peak/Actual) 7.0 / 5.0 Air Receiver (Gallons)80 Max. Pressure (PSI)175 CFM @ 100 PSI16.0 CFM @ 175 PSI14.2
Wayne |
Iron sleeve is a good thing.
Its ok to giggle and snicker, Dont laugh and point |
Since you are in Columbia SC I would assume that you have a Tractor Supply somewhere nearby. I would check there. I looked locally and they have a 60 gallon 5hp Ingersol Rand for $849 that produces a little over 18 cfm @ 90 PSI. I dont know who builds the Kobalt compressors.....probably Cambell Hausfeld. It probably is not rated at 100% duty cycle, the IR is.
A sand blaster will use about 15 cfm @ 80 psi. General rule of thumb is take the air consumption for the tool that uses the most air and add 30% to it. 15 cfm +30% = 19.5 cfm................otherwise the compressor will probably run a LOT using the blaster. If you dont plan to blast often then the 18+ cfm along with the 100% duty cycle may be OK. The 14 for the Kobalt nor the 16 for the Cambell wouldnt in my opinion. I have been looking and researching too for about 4 months now and in my opinion for the money the IR at TSC seems to be the best bang for the buck.......they also typically have them in stock so there isnt any shipping BS. Another point.........parts for IR are easy to obtain if you would ever happen to need them. The IR or any other good name brand rig would last you a lifetime. The Campbell, Kobalt, Husky and other cheaper compressors seem to be kind of hit or miss.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin Last edited by Colin; 05-28-2008 at 03:24 AM. |
Oh yeah.......iron sleeve is a good thing but its better for the entire pump to be iron. You do NOT want an oiless pump either.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
