Old 05-22-2008, 05:33 AM
troy_barker's Avatar
troy_barker troy_barker is offline
Default idler arm bolts?
Ok before I get the song and dance about not having the manuals to look at let me just say I did purchase an assembly manual and have looked at it.
However the quality is not not very good and I can't make out which type of bolts are used to attach the idler arm.
Any help identifying the bolts would be great.
I don't mean to sound like a smart a$$, but while doing the search I found many answer to post that start off with buy a manual.
I am in the process of getting my frame ready so I can sit the body back on the frame. Then I can finish the body work.
Also going to need the ID of the bolts for the steering box as well.
I took ALOT of pictures prior to disassembly and bagged and labeled all of the bags. However I guess some things just did not get bagged correctly.
Thanks Troy
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
Old 05-22-2008, 09:31 AM
bobbyj1's Avatar
bobbyj1 bobbyj1 is offline
The Steering box bolts are longish and kinda pointy on the end. I would recomend new ones, they are not expensive and the originals could be pretty rust. The Idler arm bolts are just regular bolts, I am unsure of the size.
67 GTO Hardtop
Old 05-22-2008, 01:21 PM
engineer engineer is offline
Yeah, glad to see someone has taken the time to get a manual and do some research before the questions begin. The steering box bolts are as bobbyj1 describes, although I have reused them in every car without issues, but appearance to me is secondary. Will look at idler bolts and get back to you.
Old 05-27-2008, 01:14 AM
ok, I found the steering box bolts, I only found 3 but I am thinking that is all it takes even if there are 4 holes. I think I only seen 3 holes in the frame
previously owned
78 Firebird
67 Nova
64 Nova
Old 05-27-2008, 02:55 AM
goatman55's Avatar
goatman55 goatman55 is offline
The idler arm uses standard bolts 3/8" (possibly 7/16"). Using grade 8 bolts wouldn't be a bad idea. The factory used the pinch style locking nuts, with the beveled outside edge. A good hardware store should have nuts like that. I strongly reccommend using these because I've had an idler arm come unbolted, which was scary.
Dave
Old 05-27-2008, 10:40 AM
bobbyj1's Avatar
There are only 3 bolts for the steering box.
67 GTO Hardtop
Old 05-28-2008, 03:56 AM
thanks, got it.
I am using grade 8 hardware on the front and rear.
previously owned
78 Firebird
67 Nova
64 Nova
Old 05-28-2008, 05:48 PM
Ed at PY's Avatar
Ed at PY Ed at PY is offline
PY Staff - Tech
Hey guys,
PY does carry the bolts,nuts, and washers and the part # is RPU122B.
Old 05-28-2008, 09:05 PM
fyrffytr1's Avatar
I have to take my idler arm out tomorrow evening. If you want I can post some pics of the bolts.
Old 05-30-2008, 05:45 AM
sure if you don't mind posting pics of the bolts that would help alot, I am sure I have them just have to know what I am looking for.
It will give me something else to do.
previously owned
78 Firebird
67 Nova
64 Nova
Old 05-30-2008, 08:17 PM
fyrffytr1's Avatar
Here you go. Bolts are 1 1/2" long and use a 9/16" wrench. Bolt and thick washer go through the frame rail.
I can't get the picture to upload. There is a problem with the server. If you want I can e-mail it to you. Let me know.
Old 05-31-2008, 09:14 PM
fyrffytr1's Avatar
Troy, try this link
Old 06-01-2008, 04:47 PM
link did not work, I will look around later today and see if I can finds them. thanks
previously owned
78 Firebird
67 Nova
64 Nova
Old 06-01-2008, 08:36 PM
fyrffytr1's Avatar
Here they are. 1 1/2" long. Nut and bolt are both 9/16 drive. Bolt and washer go through frame rail.
Old 06-03-2008, 01:10 AM
ok, found them, thanks for all of your help
Troy
previously owned
78 Firebird
67 Nova
64 Nova
