428 YY code question
Hi
I have a YY coded 428cid, that should be a 360 hp from 1967, or? Over the YY code its stamped 2932780. Is this the last 7 digits in the VIN number that this engine had belonged too?
1948 Hudson 1948 Pontiac streamliner 1959 Oldsmobile 2dr post 1967 Ford F100 1972 Chevelle 1975 Buick LeSabre conv |
It should be a 67, but you can find the date code at the rear of the distributer plateau. It will be three or for digits, starting with a letter. A for January, B for Febuary, etc. The last number will be the last number of the year that the block wast cast. It could have a 6 and still be a 67 if it was cast in late 66. The number over the YY is just a sequential number.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
I will check the numbers at the intake.
I'm pretty sure the 2932780 number is the VIN of the car it came out of, I believe they started doing that in 1967. If you go to the Wallace Racing website and look at the Pontiac engine code search feature, a YY block comes up as one of the following:
1967 428 360 HP 1973 400 200/230 HP 1974 455 250 HP 1975 455 200 HP 1976 400 185 HP The Wallace Racing site has a lot of other information about how to ID Pontiac parts. http://www.wallaceracing.com/ |
Here are 2 pics, bad quality, but gives you a clue.
