Front sway bar bolt hitting upper ball joint??
Help, i jacked up my 67 gto to change over to disc brakes and the stupid bolt thats thru the lower a arm thats holding sway bar in is hitting the upper ball joint stud after its tightened up. What did i do wrong?? sequence is bolt then rubber bushing then washer then long filler tube then washer, then bushing and then same on top of sway bar. Its the same on other side and its not hitting on drivers side?? What did i do wrong??
Could just be that the endlinks are too long. Remove them, wiggle the sway bar where you want, and then measure between the LCA and the arm. Take that measurement to Autozone or the like - they have about 6 different lengths of Energy Suspension endlinks in stock.
Another solution is to turn the endlink bolt over so that the threads face down, that might gain you some clearance.
Matt 1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor 1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD 1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring| 1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners 2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD 2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles |
no problem....
I think this is fine. Just put the weight on the wheels, problem solved?
I seem to remember when I assembled mine I had the same issue.
1969 Judge, 4-speed, CR/Parchment, Quasi-Survivor, #'s match - under restoration |
They sway bar ain't too far to the right or left is it? Make sure it's even on your frame brackets and double check the new end links with the old to make sure they're the right length.
"Trust me friend, a hundred years goes faster than you think." -Kenny Chesney "Go fast, turn left, hang on, go straight, go faster...who wouldn't wanna piss off 900 angry horses?" 1967 Pontiac Firebird 400 Coupe 1966 Chevrolet Corvair Monza 110 Convertible 1965 Oldsmobile F85 Cutlass 350 HO Coupe, soon to have Olds 403 1970 Chevrolet Nova 383 Coupe, NEW! 2007 GMC Sierra 5.3 Z71 Ext. 2007 GMC Yukon 5.3 SLT |
Put it on the ground before you go any farther.
. . . . I'll bet they fit now.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I believe you guys hit the nail on the head, once weight and tire is on will make a world of differance, Thanks for your great answers
