Hi everyone,
I had posted a while ago about the lifter tick in my motor. With the valve cover off, I found nothing unusual with it, rocker arm was tight, pushrod was not bent. I did a couple of oil changes with a couple of quarts of Mytery Oil with each change, and no difference. The motor is a 74 400 in a Trans Am, basically stock except for the intake/carb, some 22 year old low rpm cam and Flowmaster exhaust. Fast Forward to now. I decided to swap my Performer intake with an RPM, and at the same time take the valley pan off and take a look see. Since I have not done anything this involved (for me ![]() 1. after removing the two bolts, will the valley pan come off with the screwdriver method? I tried prying a bit, but it did not want to budge. Hope there is not another hidden bolt, and it is just 20+ years of rtv. 2. What should I look for in diagnosing the lifter tick? Would it be stuck in one position? any signs that will automatically tell me it is bad? or is there anything else in there I can look for besides the lifter for the tick noise? 3. The Performer had a nipple in front of the carb for the PCV valve to hook to, the RPM doesn't. It has a nipple in the back of the carb. From all the reading I have done today, front of the carb is preferred. So can I hook the PCV valve to the port in the back of the carb (Holley Double Pump) and the brake booster to the back nipple of the manifold, or vice versa? I have searched all day, so be gentle on me. I am a newb when it comes to this stuff ![]()
Panos Little Miss G Racing |
1. Two bolts and years of being there are holding it down. Lever on it a little. It will come up.
2. If the lifters are shot, the cam will show obvious signs of wear. If it's just ticking a little, welcome to the world of older Pontiacs. A combination of worn rockers, tired lifters etc all contribute. If it's not loud ticking, I wouldn't worry. 3. Dunno........
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
That lifter tick you hear may be an exhaust leak, they sound a lot alike. Check for the exhaust leak before you do the other work.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
![]() Quote:
![]() Thanks for that tip ![]()
![]() Quote:
1. You were right. Little more effort and it came out. 2. Everything inside looked mint ![]() ![]() ![]() And to boot, I was able to check the date code at the distributor,the two stamps were I183 and 74, which agrees with the PHS documents ![]() ![]() Exciting stuff ![]() ![]()
