holley carb bowl bolts
Does anyone have a part number for a heli-coil kit for repairing a holley carb. main body where the fuel bowl bolts screw in ? Thanks.
When I get home I will find the box and post it up and in case you were wondering...I found out the the hard way as well! LOL FYI, the kit was around $80.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Couldnt you just get a heli-coil kit from the hardware store?
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot |
bad69bird.
I appreciate it ! |
We sell the kit at Summit for $90.39. Part# Holley 26-2 . You can buy just the inserts under part# hly-26-3 for $22.99.
i am not sure if you can get it from a hardware store
i went through this last summer PITA, sorta however was easy to do and haven't had a problem since only one was stripped out VERY soft threads on the body so they will strip easy |
If you have a Carquest near you check them for a kit 12-24 coarse comes with 12 inserts the proper tap and install tool..
I bought mine a long time ago cant remember the price but i know it wasnt near 80.00 it was more in the mid 20.00`s P/N on the package is cpf 49012 individual P/N`s are inserts 49039 inst tool 49093 tap 49066 this is what they look like http://www.acehardware.com/product/i...entPage=family Last edited by Formulas; 03-12-2008 at 06:42 PM. |
Thanks alot for the replies.
Stripped out the threads in my carb also !! At Ace Hardware I got HeliCoil part number 5521-4. It does require a 17/64 drill bit, which they also had.
Good luck, Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
