swapping manual steering for PS gearbox on a 68
My friend is offering me his stock PS gearbox from a 68 camaro. What do i need to swap it with my stock manual gearbox on my 68 bird? Aside from the power steering pump, is there anything else I need to change? How about the pitman arm?
thanks |
The power steering pitman arm and idler arm are different to the best of my knowledge. My 2 PS arms from Firebirds, were also different than a CAmaro. my arms were kind of a "C" shape and shorter overall length.
Hope this helps. |
The Following User Says Thank You to boater bill For This Useful Post: | ||
Ive got the correct V-8 one for sale if you want to look at the pic for reference
you probably wont find a nicer one out there. http://forums.maxperformanceinc.com/...d.php?t=533081 http://forums.maxperformanceinc.com/...d.php?t=534577 Last edited by Cammer-6; 09-18-2007 at 09:28 AM. |
The Following User Says Thank You to Cammer-6 For This Useful Post: | ||
The only thing you have to change is the pitman arm. Maybe the rag joint if its tore up
Some parts to check to make sure they are the same:
idler arm (if the pitman is different, the idler is probably different too) drag link may be larger diameter on ps setup steering arms are probably different |
The Following User Says Thank You to Kurt S For This Useful Post: | ||
You only have to change to the C shaped pitman arm if using the 1967-68-69 center dump exhaust. After that, the exhaust went to the rear and you can then use the straight pitman arm. Just as with headers, you can use the straight arm. |
