Old 08-30-2007, 09:42 PM
FNFGTO's Avatar
FNFGTO FNFGTO is offline
Default 2001 GMC Yukon wheel bearing replacement
Anybody ever replace the front bearings on a 2001 GMC Yukon?
Old 08-30-2007, 09:51 PM
goatnut's Avatar
goatnut goatnut is offline
yes is it just rwd or a 4x4?
Old 08-30-2007, 09:58 PM
FNFGTO's Avatar
4X4, makes an awful sqweel on drivers side when I turn sharp right!
Old 08-30-2007, 10:09 PM
george kujanski's Avatar
I did on my 2001. You need to replace the entire hub; the bearings are not individually servicable. Auto zone has a Timken hub for around $130, if I remember correctly.
If it's the bearings, why would it squeal only on a sharp right turn?
George
Old 08-30-2007, 10:51 PM
FNFGTO's Avatar
What else do you think? CV jounts on short shafts? Dunno!
Old 08-30-2007, 11:34 PM
tomnt's Avatar
tomnt tomnt is offline
Possible wear indicator on front brakes.
Old 08-31-2007, 07:51 AM
FNFGTO's Avatar
New pads & rotors. Noise was there before and after.
Old 08-31-2007, 09:25 AM
TxGoats's Avatar
TxGoats TxGoats is offline
It's not a tire rubbing is it? or maybe your power streering pump?
'68 GTO 4 speed
Life is short, don't waste time worrying about the small stuff!
Old 08-31-2007, 03:09 PM
goatnut's Avatar
wheel bearings usually sound like a growling noise if bad enough will almost sound like an airplane when driving down the road. i would check the disc rotor backing plate for rubbing agianst the rotor the wheel/rotor assy will flex alittle when cornering and make contact.let us know what you find.
Old 08-31-2007, 06:18 PM
I had a bad bearing on my front-wheel driver years ago. At speed it felt/sounded like a buzz from the front wheel.
Took it off and spun the hub by hand and the only thing i was able to notice was a little 'tick' once or twice per revolution. If I were to take it from a pile of hubs, i would actually think it was fine.
Put on a new one and the buzz was gone.
My son had one on a 80's Buick Regal. this one actually was more of a howl and I could feel it when rotating the tire/wheel. Took it off, and again, the hub by itself didn't seem all that bad.
George
Old 09-02-2007, 01:24 AM
Tennesseestorm's Avatar
Tennesseestorm Tennesseestorm is offline
Location: extreme northeast Tennessee (Tri-Cities metro)
No, but my aunt recently bought a very low miles, like new 01' Yukon and the other day her power steering pump went out. I am not sure if they have repaired it yet or not.
