Old 08-23-2007, 11:45 PM
pggto's Avatar
pggto pggto is offline
Default 4 Speed Install
Do you neeed to put some grease on the splines before you slide the trans into place? Do you put some on the throw out bearing or shaft? Thanks
Old 08-23-2007, 11:55 PM
Z Code 400 Z Code 400 is offline
I apply an anti-seize lubricant to the splines and a good, quality EP grease to the throwout bearig collar (fill the groove inside) and the area on the front bearing retainer where it rides...Robert
Old 08-24-2007, 07:23 AM
pggto's Avatar
Whats "EP" grease? Thanks
Old 08-24-2007, 09:01 AM
EP = Extreme Pressure
Old 08-24-2007, 09:11 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Like a good quality wheel bearing grease.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 08-24-2007, 01:46 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I wouldn't put anything on the splines or throwout bearing. If it gets on the clutch, you'll ruin it.
http://www.pontiacpower.org/
Old 08-24-2007, 02:09 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
I agree - the throw out bearing should be adequately greased from the manufacturer out of the box.
My recent install of my Ram Long Style PP and disc into my '63 LeMans showed a little grease coming from the throw out bearing after I broke the trans in.
Old 08-24-2007, 02:40 PM
If the splines on the clutch disc and input shaft are completely dry they stand a chance of seizing together. I have seen this a few times and it makes for a challenging time if the transmission or engine ever have to come out.
Old 08-24-2007, 03:18 PM
Billy177's Avatar
Billy177 Billy177 is offline
I put a little on the tip where it rides in the pilot bushing/bearing, the pivot ball and where the throwout bearing rides on the bearing retainer.
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
