78 TA trans question
Which TH400 trans will fit in a 78 TA? A long or short tail? Thanks for any advice.
Short will fit the best.
OK, Thanks
Switched a 4-speed over to a short shaft 400 once. Think we had to move the crossmember back, drill new holes in the frame, driveshaft was a bolt in.
That's what I was wanting to do. That would be great if I can reuse the driveshaft. Pitch
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
There are at least three trans possibilities.
TH400 Short 32 spline TH400 Long 32 Spline TH400 Long 27 spline Any could work, the short was OEM for 70-74 The 27 spline is mid/late 70's and probably not as strong as the 32 spline. Unless you currently have a 71-81 4 speed, you will need to shorten your driveshaft. If you have a TH350 now, you will need to change your yoke uless you use the 27 spline TH400. I believe the 78 OEM crossmember is the same as the 70-74 TH400 except it has one slot versus two for the tranny mount. I have a repro TH400 x-member for sale in case your interested, pm me.
Gregg V. |
