Curious - What did You Pay For Your Engine Build?
Getting ready to send another motor off and I'm curious what the average price is for a street / strip motor (9.5 compression, good head work, etc) assuming the block, crank, heads, etc check good?
Thanks! Mark
71 Firebird Custom - Fuel Injected & Over-drived! Last edited by Hawk397; 08-09-2007 at 04:47 PM. |
I think i have 6-7000 CAD into mine (i assembled).
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
for me ( hope the wife does not see this )
Shortblock bought from py member 2200 offset with new rods it came with and sold a crank -800 Heads bought from PY member (Jim Yanoski prepped) 1100 RPM bought from PY 125 Machine work and all parts needed, pistons, pins, gaskets,cam lifters, pushrods/guides/oil pump, timing chain, flowed heads, dist, plugs, some hardware, carb (ebay), check all tolerances, balance, final hone a +35 , dyno time 5500 8100 I'm not sure mine qulaifes for a street rebuild. It is a high quality street/strip rebuild by a very reputiable local machinist who stands by his work. |
Holy Moly, I must be a "CHEAP" bast........! You guys are spending $6000.00 to $8100.00 just on the engine. Hmmmm, I can account for everything carb to oil pan on my 406 and it only comes to $3,327.00
My largest "Big ticket item" are the 1968 #16 heads, total to date cost $1200.00 I do have some future upgrades that will raise the cost $1000.00 I have to show this stuff to my wife, so she can stop complaining about how much I spend! This here is good stuff! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
Good to know! I had my last 400 done for around $4,800.
- New pistons, roller rockers, roller camshaft - All machine work including port/polish heads, valve job, etc Mark
71 Firebird Custom - Fuel Injected & Over-drived! |
7-8000 at least but was hoping around five when started
My price included, comp full roller rockers, several hours of carb work, break in time, full stud kit, many dyno pulls and some tuning.
He gave me price on parts prices within 10% of summit. |
Hi,
$300 for a 1970 YH 455 complete. $3667 for a long block rebuild. New pistons for 9.34:1 compression, lots of work on the heads to include screw in studs, 1.77" exhaust valves, hardened seats, pushrod holes elongated for 1.65:1 rockers. XE-268 cam, lifters, springs, valve stem seals, polylocks, bearings, gaskets, oil pump, tanked, magnafluxed, turned crank journals, boring 0.030" over, reconditioning the connecting rods, block decked, chambers CC'ed, balancing, etc. Carb and dist were worked on by CliffR and SunTuned previously. Installed a Pypes 2.5" X-Pipe complete exhaust system. Not a monster engine, but great for my needs. Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
5100 with E heads ( 455) street
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
my orig 455 = free
crower rods/srp pisons = 900 perf rpm = 125 tri-y headers = 550 6x heads (ported,titanium retainers,comp springs,x-over filled,RAIV valves, 45deg)= 900 custom hyd cam from straightline perf. anf lifters = 225 msd billet and 6al- 460 holley 830 = all said and done with almost 900 into this thing all machine work - 35 over with torque plate, line bore all the usual stuff was about 750 4800$ plus misc stuff like bearings gaskets etc etc and im prob at 5200$ than you have trans (700r4 with 10' conv) fuel system ( 2 summit pumps number 6 for nitrous side 1/2 alum for motor side, two regs) exhaust (3' xpipe pypes flowmaster 40series) rear (12 bolt 390 posi ssm lowers adj upper) rim/tire combos all said and done im prob 10-11,000
71 grand prix SJ 4280# 462 new for 2008 - 8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way! |
This one will cost.....
.....around 10K by the time it's done.
1969 400 2-bolt main, stock 400 N crank, +.030 Ross pistons, Eagle 6.625" rods, ATI Super Damper. Out-of-the-box 72cc E-heads, bathtub tunnel ram with two 575cfm 1966 Pontiac Carter AFBs. HO Racing Tri-Y headers, RobbMc 550HP mechanical fuel pump. Undecided on cam, will be running 1.65 Crower stainless roller rockers. By the time you buy all the stuff to make it come together, it adds up to more than you'd think. Plus I paid stupid money for the intake. No $400-500 fabricated valve covers though.
Less than $4K for my pump gas 455. That was carb to oil pan. For the race gas 467, I stopped counting the receipts when they got to $8K.
Had a 428 built by greg merrick for 10500 give or take and it was worth it at twice the price. The attention paid to detail by this man is scary....oh yeah, so is the motor. When the motor arrived it was perfectly jetted and ready to run! Cant wait to take on the 572 bowties!
434 CI TKO600RR 1969 Carousel Red RAII Heads...Pump gas 400+hp/450+tq at the wheels...life is good! |
stopped counting at 5 g's..........a well built motor with good parts ain't "cheap"...
a good core is gonna set most people back 500-1000 to start with....... add a good set of light pistons at 500.00 good rods at 400-600 a good set of heads at 1200-2000......you are down 3-4 g's before you can blink an eye......and thats without one ounce of machine work......
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
I have 1500-2000 out of my pocket in mine including machine work, doing the assembly myself. The 3500 insurance check from e-bay due to the motor comming with a spun bearing helped a lot.
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
with all the machine work and parts, I stopped adding at 8,000. Its like a bad drug addiction .I cant stop trying new things. I need help. I cant leave a good thing alone!!!
I think with heads and everything was around 5500... not cheap for a good motor build!
paid $800 for a 389 tripower core engine.Have right at 5K in it with the tripower rebuild.Dished pistons,forged rods balanced etc.My shop charges $1000 to assm.Tom
I will let you know once I get mine back from the Dude, hopefully before it snows
Paid $500.00 for a 400 block, Dude will 30 over and stroke it to a 455, if it runs good (and I got bucks) I will install a blower (over this or next winter). With the blower and installation help I expect to be close to 10 grand. Its only money: I don't drink, I don't do drugs, I don't gamble...........wait a minute I HAVE NO LIFE!!!!.........oh wait a minute I do have my car and sex and food (maybe not in that exact order).............that will do
Can do the talk, can't do the walk......therefore need deep pockets Injection is nice but I rather be blown If you got it flaunt it, if not fake it (Snoopy) Original 1977 Firebird / Welded tube frame connectors TH350 with shift kit / 400 bored/stroked to 455 by PDude OCD=Waxing and polishing your oil filter SICK=wetsanding your exhaust pipe |
Speed is like a crack habit, and asking for totals is like reminding someone how much they need therapy!
I had the block, bought a stroker assbly for 1900 to my door with a couple odds & ends (pump, gaskets, etc). Machine work was about 600, carb, intake, pan, etc, @1k. So what's that, 3500 or so? Pump gas street engine, won't even start on the blower engine! I will need therapy if I did! Oh, then I added e-heads, forgot about that, tack on 2300....
