Anyone using one of these
Oil filter delete from 61 Tempest 4 cylinder motor????
Plus (drag race only) or Minuses???? At what speed does the oil flow through the paper filter???
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
Hot rod deal and bad for oil flow as you have a high pressure then an expansion then the oil has to try and regain velocity on the upper passage of the block.
If you want to do that deal better to just use fittings and some stainless tubing. They used to use those on "Rails" where the oil filter would get in the way. Tom V.
I can think of few minuses and only one positive and that being the extra room it may provide.
Fram publishes flow numbers on their HP series filters. I haven't seen flow numbers on normal street type filters although I'd imagine they are avalable. |
I read it also, gets rid of the weight of the filter, and a quart (or whatever) of oil weight, and the filter housing weight. The 61 tempest one is aluminum I was asking about the oil speed because, I had read it was 50 mph and would blow shavings and such through the filter medium at that speed. Oh it was a 60# pump too.
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. Last edited by tikiklubracing; 08-04-2007 at 11:15 PM. |
Bruce Fulper had some of those 61 Tempest 4 cyl plates made up and is selling them for 20 bucks but i won't use one. I enclosed a link from Mr Fulpers site for you to read, i do not agree with Bruce on the bypass deal. Been installing a 3/8" pipe plug in mine for over 30 years with no problems. http://www.pontiacpower.com/FAQ12.htm
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
Wasn't too long ago this was covered, but for a quick recap:
It would be hard to find a filter today that did not have a built in bypass to relieve pressure. The filter has a big spring in the bottom and the element simply moves down and relieves pressure. Correct me, but Chevy's have the filter attachment cast in the block and they have no additional bypass. Could this have been a Pontiac thing only that is in place in case a filter was used with no built-in bypass? No remote mounted filter adapter has any type of bypass built in to it. So all of us that are running remote filters are doing the same thing as plugging the adapter, just a little further away from the block. Most high pressures are generated by the oil fighting the clearances in the engine and the pressure is going to be the same whether there is a filter in line or not. Cheap filter might balloon and blow, but that's what you get for running a cheap filter. I have never, ever cut a filter open and saw any "bullet" holes in the filter media. In fact, if there is crap it is on the proper side of the filter. If I had not run a filter I would know right where the pieces are - imbedded in my bearings on the next pass of the oil. Cosidering the area of the media I would bet the flow of oil through any part of it is rather mellow.
Gregg V. |
On my dragster because of clearance problems I made a plate that looks like the tempest plate, at the time I had never seen one of the ones for a tempest. I put a screen in mine, I don't think it would have caught anything, I used the screen for a couple of years and never found anything in it. I don't have the screen in it anymore, and just pulled the pan after close to a hundred passes and bearings look like new. I change the oil every other race weekend, then reuse it in my old chevy truck.
Depending on what type of filters you are putting on your remote mount determines if there is a pressure relief. tiki, Wix is also my filter of choice. Post #3 WASN"T a plug for fram. |
" Darksiders Rule "
Fulper site is where I read the 50 mph thingy, and
I started wondering. Figured someone here would know for sure. Quote;.....tiki, Wix is also my filter of choice. Post #3 WASN"T a plug for fram. I'm hip to the cut of your jib.
