crank pulley size and throttle bracket question
I'M STARTING TO REASSEMBLE A 72 400 AT THAT HAD A/C INTO A 71 BODY.MY QUESTION IS THERE A PROBLEM WITH THE A/C PULLEY SIZING?SHOULD I GET A NON A/C PULLEY AND IS ONLY THE CRANK ONE DIFFERENT?MINE IS 8IN. I'M USING A 4 CORE RAD.ALSO THE 400 IS NOW A MILD 462.
SECOND QUESTION IS DO I NEED A 71 THROTTLE BRACKET TO WORK WITH THE STOCK 71 THROTTLE CABLE? HELP WOULD BE APPRECIATED.THANKS,JOE
(THIS IS IN A GTO)
