Old 06-14-2007, 11:23 PM
70 PEPPER GREEN 70 PEPPER GREEN is offline
Default 1970 REGULAR FUEL STICKER LOCATION?
JUST READY TO FINISH MY 70 WT ENGIN REBUILD AND PUT THE MOTOR BACK ON THE FRAME OFF. THERE IS A STICKER THAT GOES ON THE VALVE COVER THAT SAYS (REGULAR FUEL) I AM NOT SURE WHICH VALVE COVER AND WEATHER IT IS TWDS FRONT OR BACK. ANY HELP GREATLY APPRICATED
Old 06-15-2007, 01:06 AM
Ron Landis's Avatar
Cool Well...
I judges a '70 at the Nat's one year that had it on the forward area of the driver side cover. Owner swears it was original. Best I can do. Ron
Old 06-15-2007, 02:03 AM
Default THANKS
THANK YOU VERY MUCH!!!!
Old 06-15-2007, 03:54 PM
BobsGTO's Avatar
BobsGTO BobsGTO is offline
I could be wrong, but I thought the "Regular Fuel" sticker only went on the low compression 400 V8 engine (code XX), not the high compression 400 WT engine, which still required Premium fuel "in the day." Anyone else know if that's correct?
Thanks,
Bob M.
1970 GTO Convertible
Originally: Sierra Yellow/Sandalwood Int/ Sandalwood Top w/ 400 4BBL Auto Trans
Currently: Red/Sandalwood Int/White Top w/ 400 4BBL Manual Trans
Built in Baltimore Plant - 1st week of Nov. 1969
Old 06-15-2007, 04:54 PM
Held for Ransom's Avatar
I don't believe any decal was on the chrome valve covers.
Old 06-15-2007, 05:49 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Exclamation
In 1970, the WT engine was rated @ 10.5:1 compression, definitely NOT regular fuel.
The regular fuel engine option on GTO's was available on '67 thru '69 models only anyway.
Included a 8.6:1 400, 2V carb, and was available with the TH400 only.
Regards,
"455HO" Lloyd
Old 06-15-2007, 08:16 PM
Default THANKS AGAIN FOR THE HELP
I SAW ON E BAY ALSO IN PONTIAC SOURCE MAGS THIS STICKER. I THOUGHT IT WAS CORRECT. SEEMS TO BE MUCH DEBATE. PARTS INDUSTRIES ON E BAY (ALSO AMES AND OTHER SOURCE BBOKS) CALLS THIS - REGULAR FUEL ENGIN - THE CORRECT STICKER FOR 1970 GTO ALSO SHOWN AS A GM RESTO PART. HOPE TO RESOLVE THIS.
Old 06-16-2007, 12:02 AM
getmygoat's Avatar
There's no real debate. HFR is right.. No decal on high performance GTO engines.. only the low compression engine. This has been discussed before, check the archives.
Old 06-16-2007, 09:47 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
does this not go for the giant two letter "GM" door sticker also?
70 GTO 400/4SPD-13.97@102.31
Old 06-17-2007, 07:37 PM
CDN2PLS2 CDN2PLS2 is offline
My two '70 Lemans 350 2bbl cars had the sticker on the cover.Not on GTO.
Old 06-27-2007, 10:08 PM
Dajudge70's Avatar
Dajudge70 Dajudge70 is offline
My chrome valve covers had no sticker nor any sign of a sticker.
Old 06-29-2007, 12:12 AM
SRR's Avatar
SRR SRR is online now
Default 70 Lemans 350 2 barrel carb...
Never on a WT engine.
― Calvin Coolidge
