100 mile bearing wipeout pics
Here are the pics I took from dissassembly of this, the 2nd time this new stroker motor has wiped out the bearings.
For those who didn't see my previous posts, I had a '78 W-72 400 block magnafluxed, leak tested, align bored, decked, bored & honed with torque plates. Short-filled hard bloc since it's .065 over. ARP main & head studs. New Eagle 4.25 stroker kit (SRP-JE pistons, file fit moly rings, H series bearings, Eagle 6.8" H-beams rods). Entire rotating assy rebalanced, surfaces polished, thrust surface polished, bearing clearances set, new cam bearings. The crank spun freely in the bearings when caps torqued down (no binding). Crower 60919 (041 RAIV copy) degreed, crower lifters, Rollmaster timing set. HS 1.65, crane pushrods, 87cc E-Heads, pistons .005 in the hole (10.39:1 compression). Performer RPM intake gasket matched & Q-Jet & MSD-HEI modified by Cliff Ruggles for this combo. The machine shop work was done at a race engine shop, and has done many Pontiacs in the past (only one around here with Pontiac torque plates). The first time together I used a RAIV 80# pump, motor knocked at 500 miles. >The second time, I paid the shop to assemble the short block thinking I might have done something wrong, they put in a new 60# pump with a new Moroso drop pickup for my new Moroso deep sump pan, and a new nonbypass Kauffman oil filter housing. They also tried 360degree grooved main bearings. Had the crank reground .010 under on mains & rods. I found bearing material in the filter at a 100 mile inspection. This thing ran like a raped ape, with no spark knock. (12 degrees intial, 36 degrees total. No signs of pre-ignition on pistons nor spark plugs). I checked the screw-in oil galley plugs, no interference with galleys. I can shine a light in the crank's main oil galley, and see light through the rod pin's oiling hole. This thing is real head scratcher... 2 times in a row, the race engine shop can't figure it out, and of course won't refund any of my money. I'm making payments on a pile of parts that won't work!!
'78 T/A W-72 400 w/468" forged stroker kit. '07 Solstice GXP (Turbo) '81 4spd Vette '03 VTX-1800c |
More pics...
Sooooo,
I got nothin.
Ah, just one thing. A riddle:
Since it all looks so shiney and new, I was wondering why there is no blue. If you are still staring, then those cam bearings are the last remaining herring. Seems the oil pressure is certainly there, I suggest your crank is a genuine scare. And I'm spent. HIS |
I don't know if this will help you or not but here is what the factory recommended for the '70 RAIV bearing spec's if I read it right:
Main: No.'s 1,2,3,4 - 0.0012-0.0028, No. 5 - 0.0007-0.0022 Rod: 0.0015-0.0031 Please confirm those spec's for yourself. If I'm looking at your pictures correctly your rods fall within the spec on the tight side for a '70 RAIV but your mains are outside on the loose end. I have no idea if it means a thing but since the factory set the RAIV up as a "loose" engine maybe the mains are too loose on your engine. I have no idea and I'm sure there must be some people out there that will know.
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato Last edited by uneasyrider; 04-17-2007 at 09:28 AM. |
Did they check the line bore the second time?
Rods side clearance? I see this quite often in the #2 main area and Pontiac blocks. |
what oil filter are you using?
1970 gto (4spd) 462 500 hp 11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. |
#2 main cap on backwards.
Then again it is very unlikely the crank would spin freely after the caps were torqued down.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s |
was it line honed before you installed the studs, I have heard that you need a line hone when you convert fron studs to bolts
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
The rods had plenty of side clearance.
I took a pic of it when it was sitting in thier Sunnen machine to be align bored: I saw the thick as heck torque plates they used for cyl boring/honing, but I didn't take pics of them though...
'78 T/A W-72 400 w/468" forged stroker kit. '07 Solstice GXP (Turbo) '81 4spd Vette '03 VTX-1800c Last edited by TnVTX; 04-17-2007 at 05:05 PM. |
But, if you notice the little "0", it's in the same position as pulled in the next pic, and the "2" is correctly oriented:
Do you run an oil cooler? Sometimes debris from a failing engine will get into the cooler and then when you run the new motor, the debris will get pumped back into the bearings etc.
It does look as if the crank is wiping the bearings more so on #2 and #4 though, so maybe the line bore is out,or a bent crank?
Oil pressure at adapter and top of block within 5 lbs ?
Oil pump clearance checked and bypass seat clean ? Crank drilled correctly and passages clear ? Cam bearings installed correctly and line up with holes in block ? Check the lifters make sure they are not chebby lifters and that grove does not pass out the lifter bore.
So then I said to myself "what would I do if I was me" ... |
What was the oil pressure with this engine? Cold, hot, when new and just before failure? Is that cam hydraulic?
