1965 tri power
Hi i am new here looking for 65 big car tri power.Could tell me what to look for correct numbers for carbs intake and linkage. Are 65 and 66 the same. Are gto same. Its for a bonn with auto and 389 any other tips or what there worth thanks
65 and 66 are different - 66 has a bigger center carb. If you are putting it on a big car - stock they used a BIG air cleaner - expensive and hard to find, GTO's had the three pots.
You can also check out the links below: http://www.pontiactripower.com/ http://www.thecarburetorshop.com/History.htm You can do a search here for tripower and then spends days reading the posts. |
Right, there's lots of tripower info to be found on this forum, just use the search feature and feel more than free to ask questions right here!
Correct Intake manifold casting number for 65 tri power is 9778818 This is the same manifold used on the big cars as well as on the GTO The carbs are the most expensive part on these setups. In 65 the center carb was a little smaller than the end carbs. Ask away! |
Is the big car carbs and linkage the same as gto . how about sta vers auto trans linkage? thanks
Originally the auto big cars used vacuum linkage. This complicated distillery of crap was pretty much disposed of by all who ran these on big cars. Some time ago I posted an exploded diagram of it all.
It is important to get the geometry of the linkage right - rods at right angles to the carbs etc. to prevent binding. There are a bunch of small Pcs you need to make it all work properly. They are expensive, but you would save yourself a ton of headaches if you bought one that was already complete. Once you get it set up & adjusted so the outboards open at WOT, it is not that big a deal keeping it all going. The airhorns do tend to loosen up & you have to continuously make sure they are tightened. It is cool, but as somebody with both, I think that other than for eye candy and the grins & giggles you can get running in 2nd & opening the outboards at will, you are better off with a good 4bbl.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
Yea your right should stay with 4 barrel but tri power just sounds and looks cool.
a little blue loctite on the carb screws slows down the loosening action.
the adjustments are the tricky part of trips. my g/p'll probably end up with the set up i had set back for the gto. mike
I will be curious to see how they compare for you.
