Vacuum line to TH 400
Sorry for the simple question. Is there a vacuum line to the trannie (TH400) - I assume there is. There has been so much switching around with the new engine I do not remeber were everything was - and the PO never connected some things (the old engine was a 350 with a Q-jet). If so, where is the best place for vacuum from a tripower setup.
Car - '64 GP Engine - '65 421 with '65 tripower Trannie - TH 400 switchpitch |
manifold vacuum
Mine is hooked to the rear of the card.
Stevep will know for certain. He probably has the mm Hg required. Good luck, Greg |
Any port that has manifold vacuum will work fine.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
I like 16-18" at idle!!! Hows that Ger I mean Greg??
I don't think I have that much vacuum with my cam (need to get everything hooked yet to check). Engine has only been run on a stand yet.
For the tripower my only vacuum options are:
My best guess would be to T into power brake vacuum line. Any confirmation or other ideas? |
i'd use option #2. it'll be about the right size.
i ususally bend up a piece of brake line to run from the modulator to the manifold and then connect it with rubber hose. that way if it rubs or gets against the exhaust it doesn't burn a hole in it. mike
