R.R.E. lifter brace
Rock and Roll engineering shows a fairly simple and inexpensive lifter brace. Has anyone tried this with any success. It looks easy to install. I thought it may be alot easier for me then a larger one. Any opinions....thoughts?
Don't waste your money!
Search RRE in the forums. There is a few good Pontiac suppliers that sell those. They are not necessarily needed unless you are running a large solid roller.
68 Firebird Are you running with the wind or breaking it? |
Exactly,waste of money.The Kauffman brace is not the best one either.Better than Fulpers pile though.I bought one of Kauffmans and did not use it.I will give you a good deal on it if you want it.But I am not into drilling and tapping right on top of the front and rear cam bearing bosses.Even then you could tear it out of a motor with a big pry bar.
The Mega Brace is the way to go.It does require some fitting but once it is in it is not going anywhere and will work as advertised. |
RRE's brace is a POS. Order the SD Performance Brace. You can order it from SD Performance, Butler, or RSB Motorsports. There maybe more that sell it but these are the only people that I know of.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
thanks, i will get a mega brace. i just liked the fact that the brace looked alot simpler to install
Can anyone post a pic of the mega brace?
Installed? Didn't see it at Butler or SD, listed but no pic. Thanks |
how much grinding is needed to fit the Mega brace?,
mine is all cleaned up, but the short block is assembled ,I'm waiting for lifters to see how everyhting fits ,can't grind now trial fit looks good against the block |
pic
http://forums.performanceyears.com/f...php?albumid=14 http://videos.streetfire.net/profile/LIB.htm Last edited by GTOLIB; 02-28-2007 at 10:52 PM. |
I'll cut my genitals off before I ever order anything from the Flopper.....
"XE cam basher" |
why does everyone hate bruce so much?
just curious.
is this thing on? |
Hey! I'm diggin' that Smurf Blue Glyptal paint in the lifter valley!
Anyone know how much HP the mega brace has taken so far while staying together??
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
Goatroper, care to enlighten me why the pistons are installed that way?
The Mega-Brace only reinforces (or bolsters) the #2 and #6 intake lifter bores. These bores do not have any support on the thrust side of the walls, and when running high lift/long duration roller cams, they tend to crack or outright "explode" from the forces imparted on them by such cams. The Mega-Brace DOES NOT strengthen the integrity of the block in the lifter valley to prevent the block from splitting up the middle between the mains and the cam bores. So it's not a question of how much HP you are making before needing such a brace in a factory block, it's how much of a roller cam you're running.
RAIV455 & Brian, you both better look at Goatroper's picture again. If you really look, those are the 4 valve relief pistons.
Had a couple extras - figured I'd use 'em up.
