Old 02-20-2007, 06:59 AM
JUDGEMAN70 JUDGEMAN70 is offline
Default WARPED DOOR PANELS
I have some nice original interior door panels that are warped. I have been trying to flatten them with a piece of plywood and weights for the past couple weeks and this process has not done a bit of straightening. Is there anything else that woud work or is it hopeless trying to flatten them?
Old 02-20-2007, 08:24 AM
H Larson's Avatar
H Larson H Larson is offline
The reason for door-panels getting warped is water. So what you can do is spray them with water on the backside and then put them under pressure.
Hope this helps.
Hans Larson
Sweden
Old 02-23-2007, 01:52 PM
ricks69goat's Avatar
ricks69goat ricks69goat is offline
I had this problem with my rear quarter panels on my 69. I found I had to get them quite water wet and then protected them with plywood and weighed it down with 20# propane tanks. After about two weeks for complete drying they came out great and went in the car. Hope it works for you.
