New Bearings - Opinions?
Think I can get away with slapping in some new bearings, or is it going to need re-ringing, too?
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
May need align boring as well................
Tempest455 |
I'd play it safe.... just do it right. Along with the line bore don't forget to check the crank.... might need to be ground.....LOL
What the heck did that come out of? |
Yup I think just replace the bearings , oh yeah you might want to run some 90wt oil in there to quiet it down a little WHAT HAPPENED?
Does that ultra trick 2-piece crank require special bearings?
I see the #3 #4 Mains Studs promoted a let-go in the PMD casting. Go back to Factory Cap Bolts.
Rear Main shows a pair of Studs per side...roight. |
I've had some blowups, but that takes the cake!!
66 GTO |
Marvel mystery oil or STP should do it
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
""""""Don't you mean OMD casting?"""""
I do now. |
That'll buff right out!
yep- couple shims will bring that right back into alignment
my buddy just did that to his eagle stroker crank...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
J B Weld?
Like to hear which Eagle, 3.0 main or 3.25"?
Tempest455 |
Did the engine stop running?
Why assume an eagle crank or are you talking to form406? Are people looking? Olds Block. 403? with the windows under the bores? |
