74 Firebird seat belts
The rear seat belts on the drivers side must have broke and were replaced. I'm looking for a set and need to know the numbers (these are for black seat belts). Here is what I have now
Irvin belts Driver side, front, 9697033, Model 2416 Driver side, front, female end, stamped mfg by Robbins Passenger side, front, 9697032, Model 2416 Passenger side, front, female end, stamped mfg by Robbins Driver side, rear, 9660409, Model 2358 Passenger side, rear, 9660408, Model 2358 Passenger side, rear, female end, 9660408, Model 2358, stamped mfg by Robbins Thanks. Last edited by Held for Ransom; 01-13-2007 at 04:19 PM. |
My 74 AK1 belts are Irvin too, and the female ends are stamped mfg by Irvin.
The driver side rear numbers are 9696823 model 2358. The passenger side labels are the same. I assume they're original to the car, doesn't look like any were replaced. Hope that helps, Greg |
I pulled the bad seat belt assy. out last weekend and found out that it should be the original to my car but end is bad. Female end is a Superior Ind. replacement (08 93). Are yours black? And, I did post an ad in the parts wanted section.
Mine are red, but the male end doesn't look like that. I'll have to get some photos up tomorrow; all I have right now are of the passenger front female end.
Greg |
I have gutted my car for bracket racing. I have belts available. I will look tomorrow.
Dscruggs, great. If they're for sale, please reply to my post here... http://forums.maxperformanceinc.com/...d.php?t=505411 If you have numbers different than mine, I'm sure others wouldn't mind you posting them here. I believe the front belts were different later on in the '74 run (seat belt warning system box changed).
I have the seat belt warning box as well.
Here is what I have.
Some Irvin, Some Robbins DSFM, 9729695, Model 2486, Code AGA73, Stamped "Service Replacement Part. DSFF, stamped mfg by Robbins PSFM, 1699808, Model 2514, Code 18A75, Irvin (I wrote down a "1", it could have been a "9", I will check next trip outside. PSFF, stamped iii and imprinted IRVIN in the plastic DSRM, 9660409, Model 2358, Code 9A74 PSRF. 9660409, Model 2358, Irvin PSRM, 9660408, Model 2358, Code 23A74, Irvin PSRF, 9660408, Model 2358 |
