Posi Question
Ok, brought a 66 GTO home yesterday, was told it had a low gear 10 bolt posi in it, so I got it jacked up and checked it out. Pulled the cover off and it doesn't have the usual 4 springs in it. It has at least 6 springs. You can see 3 right next to each other on both openings of the carrier. May have more than 6, but you can see 6 for sure. Turned the yoke and went around 4 1/2 times before the tire came back ? Thought I counted wrong and thinking it was a 3.55 gear ratio......I tried it a couple more times. Comes out to approximately 4.5:1 gear ratio. Anybody know what this posi with extra springs is ? There is some engraving on the ring gear, bunch of numbers and letters. Rear is 55.5 inches from backing plate to backing plate ? Anyone know what its worth ? Anybody looking for one ? Little to low geared for me. Anybody want to trade for a 12 bolt posi in the 3.90-4.10 gear ratio with a little cash to boot ?
10 bolt or 12 bolt?
location? those numbers and dletters on the ring gear tell exactly the ratio take a picture or jot them down and post on here and we'll help if it has anything over a 4:00 - it won't be driving on the highway (i don't know if you can drive to test) i've got a spare 3:55 and a spare 4:56, both posi's also, on the passenger inside frame tube, if you scrape you'll find numbers - they'll tell year of the rear...what gear it came with, etc
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE |
Ok, heres the pics, the posi is a 10 bolt on the cover and 10 bolt ring gear. You can see 3 springs through each hole.....so at least 6 springs, can't see if there is more in there...not much for visibility. The number on the ring gear is, 1518N BL006 010. The B might be a 13. By turning the wheels it looks like it is a 4.56 gear. I have never seen this 6 spring type posi before though. Any ideas what exactly it is |
could you back away with the pictures a little?
and the numbers you need are on the side of the big ring gear they're cast into it - small move away the oil and you'll see them - i don't know what those hand-written numbers are kinda looks like there's a spacer, if i'm seeing that right which means you have a 3 series carrier most likely, and a spacer to fit 4:56 gears in it that could be a good thing....just buy whatever gears you want for it and slap 'em in i included a picture of the 12 bolt posi 4:56 i save, where you can see a spacer.... andd also you can see the numbers i need you to find on the ring gear - which tell exactly if it's a 4:56 or whatever (although you already pretty much know that) the other picture - see the scratched off area? that's where you need to look on the tube of the axle...to find the codes on that to tell what kind of a car it came out of i'm not good enough to ID that carrier by picture - with so many aftermarket ones andd whatnot maybe ID'ing the rear will help - see if it came out of an oldds - etc
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE Last edited by baron_; 10-16-2006 at 07:51 PM. |
the BL006 010 on your ring gear is the minimum and maximun backlash recomended by the manufacturer, in this case a .006 to .010...
Posi case does look like it has a spacer..........could be a Traction loc......
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
Ok, here are some more pics. Ring gear has a few numbers, looks like B9V 7206 and the axle tube has a WH code on it. The ring gear appears to have a spacer plate behind it, at least what I would assume is a spacer. Anybody know anything about this. I want to change gears in it, or sell it and buy a little more streetable posi, preferably 12 bolt 3.90 or so |
Looks like a (edit) trac lock rear carrier. Definately not a Eaton unit. COunt the teeth on the ring and pinion gears,& we'll give you a definate ratio.
Look around the bolts of the ring gear you may see a P/N or logo of the manufacturer
Phil M in sunny Arizona 70 442 71 Corvette project 96 SS Impala 05 Ram Daytona |
The original Pontiac 10 bolt Safe-T-Track used 6 springs, not 4, so it could be original. WH code on a 66 GTO is 3.55 ratio. Ratios from 3.36 & numerically higher used the same carrier. I suspect you have an aftermarket ring & pinion, which would explain the spacer.
Another explanation for the use of the ring gear spacer is using a lower
[ numerically ] ratio carrier with a higher ratio ring & pinion. |
