Help, stumped
Rebuilt bottom end of engine and all seemed fine. Started great. But can not do final adjustments because can not seem to adjust valves. Push rods will seem to work loose or nut bottoms out.I never had a lifter or valve problem before the rebuild. only thing done to heads was new seals, everything else was fine before. I have tried the cold adjust and even the get wet with oil way. Oil preasure is good and every lifter is getting lots of oil.: wolfen1949@aol.com Help need to be able to drive it before cold weather hits.
when you did bottom end did you change the cam and/or lifters?
The cam is only 2 years old and did not have a lifter or cam problem before. only did rings and bearings cause had a broken ring, Before did that all other was fine
Jam nuts or locking nuts?
stock nuts
No matter how many times I think about it, I think cam lobes must have got damaged?????
Give the Crane Kool Nuts a try. They fit over the Pontiac rocker arm studs and have the hex lock nut on top. They are only around $30.
