I have a '70 455 with Ram Air manifolds. What is the standard size of the inlets/outlets for the mufflers? I'm having a set of reproduction VOE mufflers made. The switches will come out later. By next spring maybe?
Thanks for your help. |
Nobody can help on this one?
Don't know about size for sure, I'd guess 2.25 inches
You should look into the stuff Jim Hand has for this, I think he's already made reproductions of these available, likely easier for you then having them custom made.
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
Did you add the RA manifolds for performance gains over the D ports? How did they do?
I have a 70 RA455 driver and bought PYPES set with RA manifold reproductions. My standards were missing with headers in place and havent put these on yet. |
It's Jim who's making the mufflers and I just wanted to know the inlet/outlet sizes for standard 455 with Ram Air Manifolds. I'm shocked that nobody knows this on this board. Very strange.
JL - I didn't add the manifolds they supposedly came with the car which is an original 4spd 455 with Ram Air. There has been heavy discussion about this and most people fall on the "they didn't come with" camp but Gary Cave says they did and his 29K original convertible supposedly has them too. Mine is a convert with 4spd and Gary's has automatic. As for performance gains I've never compared with anything else but the '70 Ram Air manifolds are D-port too unlike the '71 or '72 which are round ported. |
It was 2-1/4" inlet and outlet for the RA mufflers.
Thanks Held ... that's what I needed. Greatly appreciated. It's amazing how much you know about these cars. You're truly a treasure trove of information. Thanks for sharing.
![]() Quote:
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
70ra455
My 455 RA Auto car was missing original exhaust also but upon asking on here and there told that they were supposed to be D ports. Knowing the history on Caves 455 car (low and original owner from what I read) I might be looking for wrong manifolds. If I might ask...Did you have multiple replies that would say the same for the correct ones being RA manifolds instead of D ports? |
As I said in my earlier post most people fell in the "it came with logs" camp. The person I purchased this car from claimed that it came with the RA manifolds and then Gary Cave's comments (according to this board) were that his 29K mile 455 Ram Air Convertible had RA manifolds and that they were original to the car.
Soooo ... in the end I've got my car the RA manifolds and they'll stay on! ![]() Oh yeah JL ... just a note .... I believe both RA and standard manifolds in '70 were D-Ports. The only round ports in '70 were RA4 manifolds. In '71 the 455 HO came with round ports. |
There seems to be a bit of confusion here. I am positive that the RA STYLE manifolds on the 455 were D-port. As in, the same as what was used on the RAIII.
Pontiac most certainly did NOT put round-port RA (RAIV-type) manifolds on a D-port engine. |
![]() Quote:
ALL '70-'72 A-body dual exhaust mufflers had 2" ID inlets. Even on the Ram Air III/IV and HO cars. The head pipes were 2 1/4" OD right up to the muffler inlet, and then necked down to 2" OD to fit into the muffler inlet. I still have a pair of NOS '70-'72 RA III/IV/455HO A-body head pipes in my stash which are necked down to 2" at the muffler. PN's 478607 & 478609. Interestingly, ALL '70-'72 GTO's did indeed have 2 1/4" ID muffler outlets and tailpipes. Never have figured out why the engineers didn't spec 2 1/4" muffler inlets???
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 Last edited by Lloyd-TX; 10-17-2006 at 12:21 PM. |
One additional comment - regardless what anyone has heard, all 1970 455 GTO's were OEM equipped with "log" exhaust manifolds. Doesn't matter whether it was a plain GTO, or Ram Air equipped, or a Judge, TH400 or 4 speed.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
Well, I did measure some original headpipes and they were 2-1/4", that's why it took so long to answer. Muffler was missing and I made an assumption. Truely sorry if I was wrong.
![]() Quote:
The necked-down ends of those pipes you measured had obviously been cut off before you got 'em. I'd still like to know why the engineers did not spec 2 1/4" muffler inlets on the RA/HO cars!
Sorry, I call the standards exhaust manns D ports from old habit of looking for many years for parts.
Now Ive heard two decent answers to what came on my 70 455 RA GTO...standard or RA exhaust mannifolds, but still dont know 100%...lol! |
![]() Quote:
Standard log manifolds were definitely used on the '70 455 H.O. engines.
Though I don't have an answer confirmed by Pontiac engineering, I'm sure the log manifolds were used because the 455 H.O. was available in A, B, and G-body cars. Though the RA manifolds may "fit" the B and G chassis, long branch manifolds were used on these models in previous years (ex 428 H.O.). So to simplify production and increase engine availability to several models, standard log manifolds were substituted. |
One clarification. It isn't Jim Hand who is reproducing the VOE mufflers, it's his son Tom that is.
![]() Quote:
