Nitrous Crankshafts
WTB- Nirous Crankshafts that everyone is using.... Thanks
what is a nitrous crankshaft?
Redbird, did you mean nitride?
fasteddy |
Pontiac dude has them ...Billet cranks. Stiffer than any other crank.
ROTFLOL!!! |
unless he means nitrous camshaft
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
sorry about that,
I mean what is the best(brand) for taking a big shot of nitrous(250 hp+) and dont have to worry about it. I have seen the nitride. Are the for nitrous motors? Again sorry abou that |
You can purchase an old 990 crank, wait for the forgings to come out from AllPontiac, or purchase a billet.
Ken PontiacDude Keefer looks to have the best deal on a billet right now at $1300. That's roughly half of what a billet will cost elsewhere, and not far from what you'll have in a 990 crank once it's machined. I ran an Eagle 4.25" cast crank with nitrous, but I ran light pistons with aluminum rods. Was making between 750-800 HP, and it lived, but if I were to do it over again, I would never pick another cast crank.
I'm shooting for about the same HP level you were at = 800hp. I'll be running a MR-1 block, Crower 6.8 rods, and a dished Ross piston. Should I be worried? I'm guessing I'll make around 630hp N/A and add a 175 -200 shot of spray. The shortblock isn't together yet so I guess there's still time to change the crank out. Maybe one of those affordable billets P-Dude is selling? hmmm....
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
any plans, yet, for the release of the forged crank? hey, look, post 455
Old enough to know better, but still too young to care. |
details about that engine and the crank carnage is posted on the board...try searching for it. |
Just a blind squirrel looking for a nut. Last edited by Brian Baker; 08-30-2006 at 10:51 PM. |
Forged or Billet.
Use aluminum rods and light pistons. If you use a cast crank, it will flex and possibly crack the block and/or the crank itself. If you have an MR-1, I would not put in a cast crank if you plan on Nitrous.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
I would not recommend it. 600 NA HP with a cast crank and MR-1 block would be no problem. If you add NOS, ???? Like I said, I, me, wouldn't recommend it.
But I'm sure others will follow and say "No problem"
Like I said, I've tried it, and it lived...using a factory block no less and keeping the rpm below 6800. But I had the lightest parts swinging from that crank that money could buy. If I had it to do over again, I wouldn't have been so "penny wise and pound foolish". Hell, Keefer has made upwards of 1000-HP with a factory block and crank, and it lived. There are always exceptions to the norm. Build to whatever level your wallet can afford, but be advised that making the kind of HP you want with a cast crank swinging heavy steel rods is an "iffy" prospect, regardless of rpm. You're already laying out money for an aftermarket block, lay out a little more for a good crank and good rods and never, ever worry about it.
you can place an order for a billet crank with ken today and have it in your hands in february. i think he needs two more orders by November 1 to price them at $1300, otherwise they're closer to $2000.
I thought Ken's $1300 deal was for an offshore billet?
Black Bird...I went down the same road you're looking to go down. Put together a combo using an Eagle 4.25" cast crank and a factory block. Spent at least $2000 on the block and $900 on BME rods, only to have a combo whose weak link was still the block and crank. Nonetheless, it lived. Made somewhere around 50-60 passes on the motor and about 25 passes on the bottle, spraying either a 200 or a 250 shot. At 3850 lbs. race weight, it's bests were 11.40 @ 120 (1.64 60') N/A, 10.22 @ 131 (1.46 60') with a 200 shot, and 10.12 @ 135 (tire spinning 1.58 60') with a 250 shot. Would it have continued to live at this level after 100, 150, or 200 passes? I don't know, but given the money I had in the block and crank, for a little more I could have had a truly bulletproof combo. Spend once, spend wisely.
68 Firebird Are you running with the wind or breaking it? |
