fuel filter a natural fuel regulator?
i tried to start my 64 326 2bbl with a new fuel pump, toooo much gas ,flooded out., i dont have the fuel filter installed or the mesh wire filter in carb installed,, do these items act as a natural fuel regulator ??
Maybe you have a piece of trash in your needle/seat?
TxF
1979 Formula .060 455, 068, 6X-8's,Turbo 400, 3.73's |
Did'nt happen to buy a pump with a return,and then "cap off" said return did you???
i bought this one, 2 fittings i put 1 in a gas can and one up to carb.
they also had this one. Carter.
When I started my 2bbl after a fresh rebuild, I left out the brass filter. It ran rich and idled like crap. I put the fuel filter in and it smoothed right out. This also happend to me when I put my Q-jet on. Without the fuel filter, it didn't run right. I think they do help regulate the fuel.
A fuel filter might limit flow but not pressure. As the floats reach the top the volume drops to almost nothing, but the pressure then builds. Three or four filters in a row won't stop excess pressure so I would say your problem is elsewhere. What probably happened is without the filter some junk went into the carb and held open the needle valve.
no junk. new lines, new pump,one line in gas can one line to carb.. i think i have carb issues..im gonna pull it soon.
Perhaps the filters smooth out the pressure pulses from the pump so the needle and seat don't "see" the pulses.
George |
Don't overlook the above suggestion that there may be trash in the needle valve assembly even if new. Replaced my fuel line and even tho I blew it out with compressed air and ran carb cleaner thru it there was still trash in the line.
Good luck
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
well the carb has been sitting on the car since 93.. think i need to pull it off and check it out.
ok pulled the carb off.. half of the rubber gasket of the accelerator pump was stuck to the carb wall,, think that would have been causing the problem?
