Manual Steering Strike Two
Folks,
I have asked questions and gotten answers and either I am stupid (very possible actually) or just missing something. I have a 1974 Firebird I want to convert to manual steering. First I was told a 1st gen manual box would work. Got one without pitman arm. Pitman arm wont interchange. Rag joint is different. Then I was told that a mid 80s S-10 manual box would work. I was told that I would have to use my current pitman arm. Got the box, swapped the pitman arm, rag joint doesn't fit. It is a much different diameter. I checked around and so far have not found a listing for a rag joint for the S-10 box. I am being told that it used a shaft with u-joint instead of a rag joint. Can someone who has actually done this mod PM me and help me see the light? This old man would be forever grateful. |
PM SENT!! I guess not it bounced Back PM BOX is Full
Email sent instead
HEY DON,
CROSSOVER U JOINTS AND RAG JOINTS ARE READILY AVAILABLE FROM SOURCES LIKE FLAMING RIVER, LEE POWER STEERING, ETC. oops, caps lock bit me, sorry. and you ain't that old yet. what happened with the head situation?
is this thing on? |
D Scruggs,
You need the lower half of the steering shaft from the donor S-10. The part where the two halves slide into each other is what you need to use. Simply slide lower half from S-10 onto upper half of F-Body and you are finished...Robert 10851man@gmail.com |
Try Desert Valley Auto in AZ,or Hidden Valley in AZ also.I got my manual box from DV complete with pitman arm years ago.They may have what you need.
Also try Borgeson Universal.They are in my neck of the woods,and I was talkin to them at a trade show,and was told that they have all new stuff for the P/S to manual swap.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
I may have stumbled across an answer.
According to a document on the Flaming River website (Thanks Mike) The 1977 and earlier P/S box (which I started with) has a 13/16" (.813") diameter. The 78 and later has a 3/4" (.750") diameter. The S-10 box also has a 3/4" (.750"). Now I am looking for a 78 or later rag joint. |
all ya gotta do is call!
do yourself a favor and dont get a used ragjoint, buy a new one; not worth teh risk.
is this thing on? |
