Bias-ply VS Radial
Hey,
Just wondering who out there is running Bias tires out back and radials up front? and what do you think of mixing the two types of tires? Is it safe or you just going to run out of luck and its going to get you? Please let me know! Thanks |
AS far as I know, it's illegal almost everywhere to mix radials and bias ply tires and with good reason. The handling charactoristics of the tires are so different that you'd just be asking for trouble.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be. |
When I still drove my car to the track, I would run 165-15 VW tires on front and switch to slicks at the track and it drove the same.
70 Formula Old engine: 467 HO headed 6.79 1/8th mile @ 101.87 no N20. 1.44 60ft 6.23 1/8th @ 111.83 w/nitrous 1.37 60ft New Engine IAII 535 Calvin Hill Eheads Few test passes made. Tore it up. Just got it fixed. |
I've driven hundreds of miles on the street with wrinkle walls in the rear and radials at 45 psi on the front. If you know what to expect it's all good.
6RB,
I run the Firestone F-60-15 Wide ovals. I have tried the BFG 235-60-15 at the drag strip and they do not hook as well as the Bias plys. The Bias plys do begin to spin but they recover much more quickly than the BFG's. You need to run approx 40 psi in the Bias plys to make them work the best. They love gettin hot!! They drive like $h!t but they look good and hook well.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to". |
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
I had street radials on the front and MT bias slicks on the rear. Car tended to "walk around" a lot on top end even with 400 motor running at 13.5-13.7/102-105mph. When I went with my 455 to running low to mid twelves it got scary.....real scary, almost craped my pants at times. Actually put it in the grass one time...I switched to a bias front tire and it stopped the evil handling at top end !!!
I now however run Hoosier radial slicks and the bias fronts and have no problem and car is running mid 11's..... I believe this is due the 21-26 lbs of air in slicks as to 12-14 in the MT's.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
I watched someone steer a car directly into a ditch because he both replaced a worn out rag joint in the steering shaft then put on wrinkle walls and threw the go juice to the engine. He over corrected for the longest time, fighting the car until it did a 360 in the grass. |
Guess this is going to be a problem in my 68GTO:
Fronts: Goodrich Radial T/As 255-70-15 at 32-35PSI Rear: M/T ET Drag Slicks with tubes 28" x 9" x 15" at ?? PSI. What PSI ought I run them Slicks for best 60foot? What PSI ought I run them Slicks for best mid-top track behavior?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
In drive to the track. I put 165/R15 radial tires on the front and drive with Drag Radials on the back. I had ran biased slicks and they wandered alot tubed or not. I now run a radial slick and they barely have any movement. And they did run faster than the standard M/T drag radial so far.
68 Firebird Are you running with the wind or breaking it? |
Bias-ply VS Radial
hEY,
THANKS FOR ALL THE REPLIES, I AM WONDERING WHO MAKES A RADIAL SLICK? |
Hoosier seems to be the popular brand goodyear and M/T make them as well
As long as you don't mix the two on the same axle, there shouldn't be a problem.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
Wanna bet ?? !! No offence intended...
As with most things with cars, it depends on the car. On our 65 GTO race car we have been using P195R-15 up front and M/T 28-10.50 x 15 in the back for 6 years with no trouble. We use 45psi in the front and 18-20psi in the back. With Amy's KRE 463 in the car now we are running 10.40s at 130 at a race weight of 3500+lbs Way back in the day(1970s) I had found out on my heavy cars with no front sway bar and slicks on the back that the radials in the front helped with the " ruts in the track/road" issue.
"What we have here is, failure to communicate" |
...like 16PSi driveside, and 10PSi Passside, 1 airbag, 1 hop-stop bar, things of that sort.
So what should you use if you run a 26" slick. They dont make a drag radial in that size, or do they?
M/T 26" ET Street, and ET Street Radials are in 26"slick...should use a TH400.
Bias-ply VS Radial
Hey,
Been away for about a week, Ron H. What Brand and size are you running in the back for the Radial Slick? Thanks |
