Hi,
I decided to install a proper 68 GTO fuel pump to Carb tube. Mine had been butchered to install an in-line fuel filter. After discovering that I had to remove the alternator and loosen and swing the power steering pump bracket out of the way, things went well. I previously had a 1" phenolic spacer between the carb and stock cast iron intake manifold. I had to remove that to make the fuel tube connect properly. I used a new gasket between the carb and intake. I installed the correct choke cookstove to linkage rod. Throttle linkage is correct and operates smoothly. All vacuum lines (Dist Vac advance and secondary dashpot are connected. Set the curb idle to around 800 rpm. All unused vacuum ports are capped. Took the car for a test run. On WOT it drives and sounds like a 2 barrel. The great low end torque is gone. What I have I overlooked????????????????????????????????????????
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
check your linkage , do you still have wide open throttle with out the spacer?
You might have a gigantic vaccuum leak.
69 firebird |
darn I totallty missed the spot in your post where you said your linkage was ok oops lol
My son is coming over with Father's Day lunch. I will have him sit in the driver's seat and push the pedal to the floor. I'll check to make sure that the secondary linkage is fully open at WOP. There is no top secondary plate stop on this carb, so the choke can't be preventing them from opening at WOT.
The car ran really good before I decided to mess with it. Murphy's Law and I'm a Murphy.
