hood tach power wire
where would be the best place to hook up the power wire? It's connected to a connector that is plugged in the fuse box that says batt. I have to unplug it every time I get out of the car so it doesn't drain the batt. Thanks
do you have the "ACC" terminal available on the fuse box?
that one is only hot when the key is on. david p.s. "IGN" is hot only when key is on,also. you can also tap into the wiper motor HOT wire. again, only hot when key is on. |
