Intake Question
Is anybody running a victor intake in a 2 gen T/A and if so what air cleaner are you using?
Nobody running a victor intake in a firebird? My question is to determine what air cleaner I need to clear the hood. I have an after market shaker scoop attached to the hood. Note that I do not have the engine in the car and was hoping to buy everything and install in one shot. Have attached picture of car.
Transamula hood?
""Guitar groups are on the way out", "The Beatles have no future in show business" Decca Records rejection of The Beatles - 1962" |
75TA What brand shaker scoop is that??
MoJo - Yes Transamula hood, 1974 formula hood cut for a shaker scoop.
76/80bird - I wish I could tell you, but I purchased it over 15 years ago and do not recall who made it. Got it at a local speed shop at the time. |
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
That scoop is an aftermarket unit that was offered years ago by H-O Racing.
You'll be hardpressed to find one now. I have one thats patterned after the later scoops that I used before I developed the WFO unit..
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 04-03-2006 at 03:06 PM. |
larry has the sweet aircleaner and underhood accessories...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
9", 10"
Home of WFO Hyperformance Shaker induction. |
I have a similar situation. But it's a factory scoop molded into a 'glass hood, height is about 3" above the hood. Not as tall as yours.
With a Victor intake milled down slightly, 1/2" or so, and a 1/2" carb spacer installed with a HP950 carb the front air vents on the carb were about 1/2" from hitting the underside of the scoop at the front. No room for a air cleaner. |
Thanks for the responses. I guess I will have to wait and put the engine in the car. Worst case I will run without hood until I figure out something. Engine should be ready in May and will pick it up at PY Pontiac in the park event.
