pre-oiler
I think I know the answer already, but will this pre-oiler work on my 400 Pontiac? It's probably for a small block Chebby me thinks. It's 10 1/8 inches long. Thanks, Jeff
i dont see why not
I just used one for a Chevy on mine last night. worked fine.
Do you need the distributor case? Does it seal any oil passages? I used an old distributor and 1/2 inch drill, doesn't spin very fast in reverse, but I got pressure with it.
That is indeed the correct oil pump priming tool for a Pontiac, Jeff.
You'll need a 1/2 reversible drill motor to spin it hard enough to do much good. Be sure and spin it counter-clockwise (reverse).
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
I've used mine on pontiacs, no problem.
Use a drill with a chuck that requires a key to tighten onto the shank of the tool. Those hand-tighten chucks are worthless at spinning over a oil pump submerged in oil.
Home of WFO Hyperformance Shaker induction. |
Awesome, thanks all. I was hoping I didn't have to buy another one time use tool. And I do recall the reserve rotation. Again, mucho gracias, Jeff
