Aluminum Valve covers
What plug wire retainers/seperators are you running with you aluminum valve covers. Mine bolt all the way through the covers. Does anyone have pictures of ther set up they could post. Thanks a lot.
67 Firebird Best time 1.53 60' 11.35@119.34 1/4 7.35@94.48mph 1/8 3500lb. leaf springs |
i'd be interested in that...i have a few ideas i'll be trying soon though as i start setting the car up.
Moroso stand offs and wires:
Les
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Home-made tubular looms. I can remove rocker covers without touching anything else. I got the idea from aftermarket billet pieces, but took the cheap approach; cut lengths of thin-wall aluminum tubing, polished them, and pop-riveted them together and to small brackets that bolt to the heads.
how do the wires actually run in those tubular ones? would be interested in making up myself a set some sunday after noon
1972 Pontiac Lemans 350 2-brl First "old" car and researching as much as I can in trying to put it back on the road |
I haven't run the engine yet. The only concern would be if there is enough capacitance between the tubes and the wires to affect the rise time of the ignition voltage. I haven't tried to estimate or measure the capacitance- just guessing that it won't be significant (an "educated" guess, after retiring from a career in electronics).
If you build something like this, I advise not having the front mounting screws where mine are. When I drilled and tapped the heads for them, I broke into the water jacket, so I have to be careful to seal the screws. |
I prefer my seperators to remain as invisible as possible.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I also like the "less visible" separators, David. Are your friends bugging you to do aluminum polishing for them now?! |
Jack, I've had a few "WoW"s. Can't wait till cruise-in season gets rolling.
