Old 02-05-2006, 02:32 PM
Paul Brezinski Paul Brezinski is offline
Default Radiator Core Support Bushings
I tryed to install new core support bushings in my 73 Formula today and guess what ?? They did not fit.Coming up from the bottom (core support) the hole is 1 1/4" dia. But the new bushing is 1 7/16" Obviously it won't set in the hole. Is this typical or is it just more paddock Junk !!! The set was only $24.95 and now I know why !!
Old 02-05-2006, 03:04 PM
tdavidl's Avatar
tdavidl tdavidl is offline
hope this helps. pic courtesy of dennis smith.
i ordered my bushings from PY & they fit fine. one side was a little tough getting the sleeve into the hole & that was only becuase the hole didn;t seem to be perfectly round.
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 02-05-2006, 05:13 PM
Thanks tdavid, thats what I am tryng to do but the bottom part will not fit in the hole of the core support. I am going to order another set tomoorow and send the other ones back.
Old 10-30-2008, 11:02 AM
1973Formula 1973Formula is offline
Bringing this post back. What is the part number for the correct bushing kit? I bought a set from Goodmark and they will not work.
Thanks,
Tom
Old 10-30-2008, 11:24 AM
Here is the NPD catalog page.... I can't find this part in the PY catalog.....
I don't see anything for '73. I assume the others will work, but are not exact. I just need a set that fits well. My support panel is pretty rusted around the mount holes. I am going to make weld some repair rings to the panel once I have the correct bushings.
Thanks,
Old 10-30-2008, 11:55 AM
I found this in the PY catalog:
Can anyone confirm the correct part number? The hole in my support panel is so rotten, I do not know the original hole size.
Thanks,
Old 10-30-2008, 01:03 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The one in the picture came from Ames Performance. They were identical to the originals(except for the Made In Taiwan sticker!)
Old 10-30-2008, 01:12 PM
So that would be this one...
Consider this the comprehensive core support bushing thread.....
I will probably order the PY kit. It and the ames kit look very similar.
Thanks,
Old 10-30-2008, 02:31 PM
HWYSTR455's Avatar
Not sure, but doesn't look like the Ames kit comes with sleeves.
Old 10-30-2008, 03:00 PM
Dens71TA's Avatar
Mine did.
