I'm leaning towards the 50-state E-Heads, but have a couple of questions.
1) Is the heat cross-over blocked off? 2) Can I use A/C brackets?
'78 T/A W-72 400 w/468" forged stroker kit. '07 Solstice GXP (Turbo) '81 4spd Vette '03 VTX-1800c |
E heads have all the accessory bolts in the end of the heads.
The 87cc have a crossover the 72ccs don't. |
1) Is the heat cross-over blocked off? No, but much smaller opening than on stock cast iron heads.
2) Can I use A/C brackets? Yes, has the same bolt bosses as stock heads. They have 87cc combustion chambers and will give roughly 8.7:1-9.2:1 CR with a 400 block, depending on bore and deck height. 9.8:1-10.3:1 with a 455, again, depending on bore and deck height. All of which will work fine with pump gas.
John ![]() "There are no stupid questions, but there are a LOT of inquisitive idiots!" |
![]() Quote:
John
Does anybody make "ready-to-install" block off plates that I can use with the E-Heads?
I'm getting the 87cc "50-state" ones just in case they start inspections in my area, which might happen since I live close to the Smoky Mtns, and there has been some recent outcry over emmission problems in the Smokies. Anyway, I'm getting the Eagle 4.25" stroker kit, and will end up with ~462", comes with SRP flat tops w/5cc reliefs, and looks like I'll end putting them .005 in the hole. Not sure what head gaskets I'll use, but, I'd like to get ~10:1 compression when it's all done.
You can thread the cross over holes in the e-heads and block them with a pipe plug. I believe 1/2" pipe would be the correct size.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
Hammered- Great job on documenting the EFI on your engine. ( sorry dont mean to hi-jakc but wanted to give you kudos)
I was just clarifying which ones did not have the crossovers, as you said its why the 87s are "legal". All types have have the complete set of accessory holes, unlike iron D ports.
As Hammered said you can pipe plug the 87cc crossover. The heat crossover also just goes to one port I believe. You can see the passage in the 72cc casting also. |
Cool!!
Thanks guys! ![]()
I think its a 3/8 hole.... allen head set-screw works great.
I did as Hammered said, I tapped and plugged the crossover in my 87cc Eheads using a 1/2" pipe plug that uses an allen wrench to insert them. And yes, the crossover only goes in to one port. I also added a little anti-seize (per Butler's reccomendation) just incase I ever want to try to get them back out. Now there's no block off plates to worry about blowing out or leaking!
'69 FB/ 462/ E-Heads/ Comp XE 294h/ T2/ AED 850HO/ 3500 stall/ 3.70 gears |
Felpo 1233 gaskets come with a block-off "panel".
The hole in the E-head can be tapped to 1/4" NPT easily. Jim |
My bad!! It is 1/4" NPT. Just went out to the garage to check the tap that I used.
