Old 12-07-2005, 12:58 PM
1157 motor head's Avatar
1157 motor head 1157 motor head is offline
Default NEED convrt. hydraulic line fittings
please help if you can, i am looking for the hydraulic line fittings for my 70 GTO convertible top . i am in the process of replacing the lines due to the fact that they are brittle and break easy . i need the brass fittings at the cylinders and the T,s at the pump.
thanks Jim
Old 12-07-2005, 03:43 PM
engineer engineer is offline
buy the repro set. used fittings will not do you any good, unless you find new ferrules to use with the old fittings. new loose fittings are not available retail.
Old 12-08-2005, 09:37 AM
Question i'm lost
ok sounds good . i'm lost , who has the repro sets?
Old 12-08-2005, 09:51 AM
pggto's Avatar
pggto pggto is offline
1157, are you in Wild Rose, WI?
Old 12-08-2005, 10:46 AM
Cool lost in wild rose Wi.
why yes i am , i am the engineer at the only foundry in wild rose .
Old 12-15-2005, 11:05 AM
BobsGTO's Avatar
BobsGTO BobsGTO is offline
You may be able to find some fittings at Inline Tube (www.inlinetube.com) or Classic Tube (www.classictube). However, since these firms specialize in brake and fuel lines (and fittings), it would depend on if they have the proper size and threads that would work for the convertible lines. Give them a call.
If you do find a specific source for these convertible top lines and fittings, please post that information -- I am interested too.
Thanks,
Bob M.
1970 GTO Convertible
Originally: Sierra Yellow/Sandalwood Int/ Sandalwood Top w/ 400 4BBL Auto Trans
Currently: Red/Sandalwood Int/White Top w/ 400 4BBL Manual Trans
Built in Baltimore Plant - 1st week of Nov. 1969
Old 12-22-2005, 11:34 PM
GStage1's Avatar
GStage1 GStage1 is offline
www.opgi.com and www.nationalpartsdepot.com carry a conv line kit. For NPD, look it up in their Chevelle catalog
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
