Like a good mystery? Read this... :)
This cam came out of a 1970 400ci with #16 small chamber (72cc), small valve (1.96/1.66) heads. It doesn't seem to have the usual factory stamp on either end of the cam. As such, I assume it's an aftermarket cam? The numbers/letters are:
Towards the rear: 159 and then C F D Front of cam: 537 441, then a 7 a few lobes down I'd like to sell it along wth some other parts but would first like to know the specs and/or the manufacturer so I can go do some digging. Any ideas? Thanks! Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor * Engine alive and kickin' March 2nd, '06 * RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers * QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi * Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+' Last edited by tremo; 10-22-2005 at 09:33 PM. |
The numbers cast or stamped into the blank usually don't mean much, they were probably put there by the blank manufacturer, not the cam grinder. Look for identifying marks stamped into the ends of the cam, usually more helpful in identifying it. Good luck selling any used cam, especially one that looks like that...
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
I noticed the CFD is also stamped on my transmission on the bell housing and am wondering if it was a BOP corporate part # thingy.
Thanks guys, 'ppreciate it...
Will, Yeah, I was wondering the same thing re it's condition. Not being an expert, it looks worn and "burnt" to me (especially that one lobe in the bottom pic). Yes? If so, I'll just recycle it... Thanks, Jim.
* '69 Custom S - 2dr Hardtop Coupe - Rust-free Oregon survivor with all original panels and original trunk floor * Engine alive and kickin' March 2nd, '06 * RA-IV 'spec' 400 (.060-over = 410ci), balanced, Comp Cams #9794041, #16 heads (72cc converted to large valve) with 1.65 Harland Sharp Rollers * QuadraJet #7042210, HEI, Hurst V-Gate, FlowTech Headers, X-Pipe with dumps, Flowmasters, TH-350, 3.90 Posi * Best ET: 14.06 - Bandimere Speedway, CO. @ 5,800+' Last edited by tremo; 10-23-2005 at 02:11 PM. |
nothing personal but that cam is toast...id toss it in the recycle bin...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun... |
