Old 08-29-2005, 12:51 AM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
Default Ball joints VS Tremec
I was about to install the Tremec, but....
I need new ball joints upper and lower.
so, these are gona set me back 2 months.
But, I dont want to be on the highway, in the right lane at 40 MPH and have my front end fall apart...
Busy lovin Jesus......................
Darrah for President!!!
LOL
Old 08-29-2005, 07:38 PM
Shadowjack Shadowjack is offline
It's more fun (and less tension) to drive a car that goes where you point it, even with the wrong trans--once you get it into high.
Old 08-31-2005, 02:09 AM
bad ball joints can potentially kill you and someone else.
straight thru trans will just kill your wallet.
mike
former." --Albert Einstein
- Winston Churchill
Old 09-03-2005, 09:48 PM
Brandi Kay's Avatar
true that....
LOL
Old 09-05-2005, 08:29 PM
Walter Lansing's Avatar
Walter Lansing Walter Lansing is offline
Brandi,
I have had a ball joint break on me ( lower R/H ) and it is not a fun ride. I had been tuning on the car and was making a pass, in the middle of second gear all hell broke loose. Luckily I was on a two lane road with grass field on the side and needless to say that’s where I ended up. I knew the ball joints wear old but I had no idea they were that bad. To make a long story short do your ball joint and any other front end parts that need to be replaced. Hope this helps.
Walter
