and you were to replace a worn out original front suspension on a 69 FB where would you go to get your parts? I plan on getting a set of front springs and everything I need to get the front suspension done but I need GM replacements. I see kits all over but some are at different prices.
Whatyasay? TIA Mase |
First and foremost, get parts made in the USA - TRW, MOOG, Spicer.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg ![]() |
I thought those companies just made performance suspension and not exact reproduction of the OEM GM parts? I will look at them.
Thanks! Mase |
Global west or hotchkis
72 Lemans ![]() |
most of it is still available from GM the trick is knowing how to find it. most of the time if you walk into a dealer they tell you its not available but a good parts guy knows ow to cross the old numbers and can find stuff you might try Mike (ponchoshop) 219-743-8112 I have replaced almost everything on my 2nd gen TA from him
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
I am in the process of doing the same thing right now.
I found incosistent pricing on the suspension rebuild kits from performance suspension (they want 259 for a 69 camaro, but 459 for the firebird) and have heard that the parts for p-s-t and performance suspension are from china. I am not sure if that is a substantial difference, but I dont want to take the risk. So I am piecing together most of the components form using summit and PY. A little bit more difficult, but the energy suspension bushings and moog hardware and new front springs will give me a piece of mind factor. For shocks, I went with the edelbrocks.
http://members.cox.net/jim69bird/firebird.jpg |
![]() Quote:
Mase |
