I have a 323 posi carrier that I plan on putting in my 69 gto. Presently it has a 355 open rear in it. Do different gear sets have different carriers? I think that I read somewhere that I can go to 355 with that carrier, but if I want to go to the 390 or higher I have to get a different carrier. Can I use the 355 ring and pinion from the open unit on the posi carrier? I was really thinking that I would like to go to the 390 for a little more snap. Gas mileage is not an issue as I only put on 300 - 500 miles a year.
Thanks Blair |
I'm pretty sure that you will need a ring gear spacer to go from a 3.23 carrier to a 3.55 ring gear. I have heard some say that they wouldn't use a spacer, and I heard that some have used the spacer with no problems.
I'm sure someone else will chime here to help out. -Bill |
A 3.55 and a 3.23 are both "3" series carrier. I know you'd think a 3.90 would be, but it is a "4" series...spacer needed.
3.55 and 3.23 do not use the same carrier in an 8.2 ten bolt rear. A 3.23 carrier will work with 2.93, 3.08, and 3.23 gears. If you want to run 3.55 gears, you will need a 4 series carrier, which accomodates 3.36, 3.55, 3.90, and 4.33 gears. BTDT.
Jeff |
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post: | ||
Ditto! And 2.56 and 2.73 are another series as well
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
The Following User Says Thank You to north For This Useful Post: | ||
3x....
Agreed, the 8.2 is a little different than your average GM carrier. I have used MANY spacers and are not a problem for a street car. The only one we had a problem with was a 10 second drag car launching about 3500 from a tranny brake. Sheared all the bolts off.
![]() You could also order a set of gears for that carrier, they make the ring gear a little thicker to make up the difference of the smaller diameter pinion, if the spacer bothers you. Good luck with it! Dennis
The beatings will continue unless morale improves. 69' Judge R/A III 4-speed, Mayfair Maize/black interior. |
The Following User Says Thank You to RUFFJUDGE For This Useful Post: | ||
Who makes thick ring gears? I have a 2.78 and would like to run 3.55 for a street car.
Have yet to run across an aftermarket thick 8.2 PONTIAC 10 bolt gear set.
Richmond Gear & Yukon (Randys) are the only game in town for aftermarket 8.2 Pontiac early style ('64-69) gearsets. Back in the dark ages, Zoom offered several very low ratio gearsets. ZOOM was the one that came up with the great idea to refer this style gearset as B-O-P 8.2's. Something that kind of made some sense with the '64-67 Buick & Pontiac manufactured 8.2 10 bolts, absolutely no sense for after 1967. Thicker gear sets are what one occasionally runs across for several other differential styles; examples: THICK 4.10 gearset for a 12 bolt car 3 series's carrier, thin 3.73 carrier for a 12 bolt car 4 series carrier. There's also at least one thick gearset offered for GM 7.5 10 bolt's. Even some specialty run gearsets, offered for Type "O" Olds 10 bolts & 9.3 Olds/Pontiac rears are designed thicker to go on a mid ratio carrier, as the low ratio carriers are so hard to find
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
![]() Quote:
2.56 & 2.78 fit the high ratio Pontiac 8.2 carrier. 2.93-3.08-3.23 came on mid ratio carriers 3.36-3.55-3.90-4.10-4.33-4.56- - - 5.57's came or were designed for the low ratio carrier. To use a high ratio carrier w low ratio 3.55 gears, you would need both a nonexistent thick 8.2 Pontiac 3.55 gearset, & an 8.2 Chevy ring gear spacer, & a small bottle of red locktite. Not something I'd painstakingly assemble.
If you end up not using the 3.23 posi carrier and gears, I am interested.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
