I'm just planning ahead here, wondering if anyone has experience with these two intakes, and their results. Also, is Warrior Racing a good resource for parts? I'll either freshen up the 428 next fall, with a change to a roller cam, or build a new combo using a 400 4 bolt. Right now I'm leaning towards the 428 with more cam, tire, and converter. Car is a '63 LeMans weighing approx. 3200- 3400 lbs. 3.90 gears,
TH 400. Heads are ported #62's Would like all input you guys may have. Thanks.
I no longer want to die mowing the lawn! |
Stay away from Warrior Racing.
A modded Warrior (it's really a Nash) intake will flow with a stock Victor. A modded Victor will outflow anything but a sheetmetal inatake. Causin' pain like two bad nurses..... |
Agree with Bruce, on this one.
A very good "Warrior" (Nash) like the one on Jim Brady's engine was used as the benchmark for the Victors when the design work was in process by the Edelbrock team. (It originally was on David Butlers Firebird before Jim Brady bought it). Maxed out it went about 275 cfm at 25" h2o on a flow bench. A stock Victor (850 style or Dominator style) out of the box will go with-in 2% of a 282 cfm head (Edelbrock) in actual testing (276 cfm). The Warrior will make more torque at lower rpm but the Victor is a better race manifold. Tom V. ![]()
Thanks for the input, guys. I have several options ahead of me for the next more radical set-up in the LeMans. I just nailed it pretty good for the first time yesterday, and I already have traction issues. I think the ported heads really woke up this 428, it hits the tires hard. I'm just dialing everything in now, and getting prepped for paint. Trying to get to the track by July or August. I'm sure I'll have more questions, look forward to your advice.
I just got my Warrior back from Dave at SD Performance. ITs now fully ported and modified. The reason I opted to go with the Warrior over the Victor was I can still run a 1" spacer on top of it and keep everything under the hood, but I am sure you are probably using a hood scoop on your car so the Victor would probably be a good choice. You'll also have less $$ into a Victor
1967 GTO 400 4-speed (416) #62's 11:1 solid lifter 6.8 Eagle/Ross full exhaust 11.80's@116---> UPDATED, heads race ported (287/200) and extras; shooting at low 11's in the spring!
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
GOT ANY PICS?!?!?
would like to see a comparison to the warrior i have. 1973 SD455 T/A 1979 S.E. T/A http://community.webshots.com/album/16587603rOyvmFCiHs
Home of WFO Hyperformance Shaker induction. |
Look 'em over but don't over-look them!
The Warrior is the best low hood clearance intake and works suprisingly well compared to a Victor even with the low flow of the double turn runners. I was against them at first because of the small ugly runners, but HP and super Torque numbers as well as plenty of faster cars running have proven that they shouldn't be over-looked. If you can run anything, Victor and of course Sheet Metal are the top performers. -Rob |
