Old 10-09-2002, 09:13 AM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
Gonna order 2 Ignitor points conversions from Pertronix. Has anyone tried these yet? If so, any noticable power increase? Thanks!
Give me a thumbs up, tell me "Nice Car!", but for god's sake, don't call it an Impala.
_____________________________
www.classicpontiacrescue.com
Old 10-09-2002, 09:41 AM
David Jones's Avatar
If your points ign is in good shape, you will not notice an increase. Adding a Pertronix to a worn distributor won't fix it. I had the conversion on mine and noticed that the car took longer to start and had a lumpy idle. Discovered play in the distributor. I went to an HEI.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 10-09-2002, 11:07 AM
goatseeker's Avatar
goatseeker goatseeker is offline
Went to the pertronix on my stock distributor. Made a big improvement over the points. Quicker starts, better performance. Going to try the stock distributor w/pertronix & performance coil on the 462 to see how it does.
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 10-09-2002, 04:08 PM
Motornoggin Motornoggin is offline
Big thumbs up to Pertronix! I have a few of them and soon all my points cars will have them. They are almost too good to be true. Easy to install and as far as I can tell, they are bulletproof reliable! I will say that they won't cure a worn out distributor though, if the bushings are bad you should replace them. Still way cheaper than a new distributor and works every bit as good and looks stock (if that is important to you). [img]/infopop/emoticons/icon_biggrin.gif[/img]
Brakes?! We don't need no stinking brakes!
Never trust a fart. They sometimes suprise you.
http://community.webshots.com/user/motornoggin
http://motornoggin.smugmug.com/
Old 10-09-2002, 05:54 PM
GONZO's Avatar
GONZO GONZO is offline
Easy to install and work great. With older model pertronix you had to wait 5 seconds with ignition key in ON position to start car. Now they work better.
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
Old 10-09-2002, 06:36 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
If anyone is interested, I have a brand new Pertronix still in the box that has never been used. An MSD system came with the engine I bought, so I have no use for it. [img]/infopop/emoticons/icon_smile.gif[/img]
http://www.kurtspontiac.homestead.com/Dannys65GTO.html
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 10-09-2002, 06:49 PM
My Pertronix was a "lobe sensor" style. I know understand that is NOT the one you want.
Old 10-09-2002, 09:13 PM
Colorado Bill Colorado Bill is offline
Can you use the Petronix with an MSD, so you don't have to change or adjust points any more?
Old 10-10-2002, 06:40 PM
Never Enough Power Never Enough Power is offline
All of the cars that I have changed over to a Petronix unit work very. This includes my own cars and my customers vehicles. I like to add the MSD unit with the Petronix but you can use a unit of equal value to your system with the Petronix. By doing so it works even better. Both are excellent upgrades. Points will bounce at higher revs, the Petronix will not.You should have a good dist. unit no matter what you run for your ignition system.
Old 10-10-2002, 06:54 PM
They are both in good shape. Being Bonnevilles they don't get flogged like an A-body does.
Old 10-10-2002, 07:31 PM
60man's Avatar
60man 60man is offline
Hey Gonzo. I have a lobe sensing Pertronix unit and I have to wait the 4-5 seconds to start. Do I understand they make a new lobe sensing unit that is better? If I wait the 5 seconds it fires imediatly. Do you know the part number?
Outlaw Pontiac Racers Association
"For Those Who Live The Legend"
ECM member.
MANDRA
Old 10-10-2002, 07:50 PM
PonchoV8 PonchoV8 is offline
Just don't wire it up backwards or it's toast [img]/infopop/emoticons/icon_mad.gif[/img].
Don't judge another's limitations by your own.
Old 10-10-2002, 08:01 PM
60man's Avatar
Have we been there PonchoV8 ?
ECM member.
MANDRA
Old 10-17-2002, 06:52 AM
GONZO's Avatar
60man......I called pertronix when I had that problem as well, as I understand it, ALL of the new pertronix are updated and you no longer have to wait anymore, If you send it back into pertronix they will give you a new model free.
Colorado.......Yes you can use MSD with pertronix, in fact the MSD instructions show you how to wire for pertronix, very easy, no problem I just did it on a car.
Old 10-17-2002, 07:00 AM
T/A 70 T/A 70 is offline
GONZO, having a tough time reading your posts with one eye on the girl. Can you get her to turn around? [img]/infopop/emoticons/icon_redface.gif[/img]
T/A 70
I hate whiners. I most certainly do.
Old 10-17-2002, 07:46 AM
GONZO's Avatar
Can't my wife would kill me, if people started recognizing her.
Old 10-18-2002, 05:54 PM
ksgto ksgto is offline
Which one would be best in a street motor
Old 10-26-2002, 02:44 AM
retrojoe's Avatar
retrojoe retrojoe is offline
PNX-1181, not the 1181LSCC. That one is the lob sensor type. Use the "regular" one.
My other life has meaning....
"It beats pickin' cotton and waitin' to be forgotten"
Old 10-26-2002, 05:52 PM
Bonneville Joe, One thing I did not mention about your Petronix, if you decide to have Distributor Re-curved/ Dialed in , Remove Petronix, install Points, after you finish with Re-curve just re install Petronix. Have seen some of the people who used Petronix on machine end up with a dead unit after it was done. Unit was probably hooked up backwards but it is not worth the chance.
