Old 05-25-2000, 10:54 PM
Jon Dailey Jon Dailey is offline
I have a 400 in a 79 T/A with 670 heads. I don't have the bracketry for it. I need all brackets for alternator and power steering pump. E-mail to hrjim@frognet.net
Thanks -- Jon
Thanks -- Jon
Old 05-25-2000, 11:31 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Jon,
Are you using the early timing cover from 65-68 or the 69-up cover. The waterpump has 9 bolt holes for the early. 11 bolt holes for the late.
Try calling CRUSHPROOF! 512-386-9889
Old 05-28-2000, 11:46 PM
I am using the later timing cover. The engine is a '74.
Old 05-29-2000, 12:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The 79 and similar years took an alternator bracket that the main bolt threaded into the head . Early heads don't have a boss or hole(my 70 replacement RAIVs had the boss we drilled the hole.
You can make a template of some late heades and drill it(I have a set of 16 heads someone did this) but it is on an angled part of the head and will be hard to drill unless you use a press or milling machine.
Otherwise you will have to use earlier type bracketry.
Skip Fix
Old 05-29-2000, 02:55 PM
My heads don't have the boss where the hole should be. I need the earlier style bracketry. But will the early brackets work with the late timing cover? What about my p/s pump?
Old 05-30-2000, 10:59 AM
79TA 79TA is offline
(Jon Dailey) Found some at a local junkyard. Thanks a bunch for your help.
Old 06-01-2000, 02:02 PM
digger1978 digger1978 is offline
I had a nightmare with a motor I built. I used a 73 455 block with 1968 RAII heads. My brackets didn't work so I found a beater Bonneville and stripped it. Your crank pulley will not line up with the water pump or power steering pump. I had a custom crank pulley made to compensate. You can also try to shim the crank pulley yourself. I personally would use an older timing chain cover so everything works fine.
Old 06-02-2000, 07:16 AM
I found a '70 Formula with #13 heads. The timing cover is the later style, and the #13 heads have the same bolt holes as my #670's. I had to use the crank pulley and the water pump pulley from the Formula. My crank pulley was about an inch larger in diameter. My water pump pulley was about a half of an inch too long. I also had to use the p/s pump off the Formula. The best part is that the belts that I had on my 403, that I swapped out, now work on the 400. Everything bolts up perfectly. Thanks for all your help
