What's up guys?! I just got my Poncho-lovin' paws on the 66 lemans that my uncle owned forever, and after 7 long years, he finally hooked me up!!!Bless his precious soul!! The ride has a 326, and a 2 speed powerglide. The machine work has been done on my 73' 455, and I got the turbo 400 waitin in line right behind it, ready to assume it's position in the driveline. What do I need to do to get the turbo 400 to fit and work properly? Will I need a new shifter, crossmember, etc? Any help in this matter will be greatly appreciated. LONG LIVE THE PONTIAC V-8!!!! P.S. that 10 bolt's coming out, and that 12 bolt's going in.
Hey are you ready to go, got the top turned down on my GTO. Come on,let's all jump in, gonna take this car for a little spin!! |
Use 66 motor mounts, drop motor and trans in, slide old crossmember back to match the T-400 trans mount, drill new holes and bolt it in.
When I installed the 455 and T-400 in my 66 Lemans, I also bolted in a 12 bolt rear. If I remember right, I used the 66-67 GTO driveshaft and used a combiniation rear U-joint. I used an aftermarket shifter as the Lemans had the colum mounted shifter. It is really a easy swap and well worth it. Also don't forget to run a full 12 volt to your HEI. |
