Old 01-15-2001, 10:31 AM
66Bronz 66Bronz is offline
I have a couple of basic questions. Onto a 389, I'm putting on a Performer intake with stock 093 heads. 1st time for me. The main purpose of the car is to look cool and be reliable on the street. What should I torque it, being aluminum intake & cast iron heads? Should I use gasket sealer? Thanks!!!
Old 01-15-2001, 12:57 PM
STripleduce's Avatar
STripleduce STripleduce is offline
27-32 ft-lbs.Should not need sealer if done correctly starting from center working out in a criss-crosss pattern in steps of 10 lbs.
Old 01-15-2001, 02:21 PM
Black 65 GTO Black 65 GTO is offline
You might also try using Fel Pro's #1233 intake gasket for the aluminum manifold. Edelbrock used to recommend this gasket in their installation instructions. I have used these several times without any type of sealer and had no leaks. I also use an adhesive like Edelbrocks Gasketcinch, a rubber cement type substance, on the head surface to hold the gaskets in place. The #1233 gasket has the RAIV port height but I have found that by trimming the gasket you can lower and center the gasket for a good fit on a standard Pontiac port.
[img]http://photos.msn.com/imageserver/image.aspx?Image=HcZNnT9kkUh7v3gGH5Km42rZ7vcme1lp* UaM!VDE1BG*vgDalH3kuL5h3zNqazZzIGM4Vs6rS1*M8m6jwq2 RRzGpoEcUD1hew3uV4awBUsyFSmp5gkgscnHcokRZl*b8MCsY3 sAhyRgDddNSylRh*Q$$[/IMG]
Old 01-15-2001, 05:57 PM
Brian Baker's Avatar
Also be sure to tighten down the bolt that pulls the intake into the back of the water pump (at the crossover) BEFORE you pull your final torque on the intake bolts. Not doing so is asking for leaks at this junction. Try a smal dab of silicone (RTV - Permatex) on either side of the rubber O-ring that fits here as well to help seal it.
Old 01-15-2001, 10:47 PM
Half-Inch Stud's Avatar
Yea.
What Brian Baker said.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 01-15-2001, 10:49 PM
to address your point on COOL AND Reliable.
Be
certain
to
use
a
Quadra-Jet.
Old 01-16-2001, 08:39 PM
Kevin Kevin is offline
While we're on the topic of intake torque. What is the recommended torque specs for an alum. intinke into alum. heads? Would it be the same for alum onto steel? Thanks
Old 01-16-2001, 09:19 PM
Thanks guys!! torque was lower than I expected- glad I asked.
Old 01-16-2001, 09:34 PM
68Bird 68Bird is offline
I didn't know that Q-jets were so stylish. Does that make my Demon a fashion faux pas?
Old 01-16-2001, 10:09 PM
NAW, anything goes on the Left coast.
...but us Easterners are kind of funny that way. Funny I tell ya.
Old 01-16-2001, 11:57 PM
Gach's Avatar
Gach Gach is offline
How about a 800,00 Pro System Holley...LOL
Old 01-17-2001, 12:05 AM
NAW, you're too far East to use it. People would talk.
Old 01-17-2001, 01:52 AM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Any further east Lou and your hat will float, unless you can walk on water. [img]/infopop/emoticons/icon_biggrin.gif[/img]
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
