Old 09-02-2000, 10:45 PM
Guest
Posts: n/a
a friend of mine said he has a tripower 64 bonneville because of some can behind the headlights that looks like a coffee can.
he said that these are only on tripower cars.
is this true?
Guest
Posts: n/a
is this true?
Old 09-06-2000, 04:23 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
All Tri-power cars had a Vaccume can for the Tri-power. It can also be used for the vaccume trunk release. Does the car have it?
Try calling CRUSHPROOF! 512-386-9889
Old 09-06-2000, 06:46 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Factory tripower cars 64 and older were all vacuum operated. 65-66 automatics also. Thus the "reserve" can. It could also be for power "vacuum" operated door locks and I believe 1966 Big Pontiac with ATC air conditioning.
Old 09-27-2000, 07:44 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I have an absolutely Original 1966 Grand Prix with ATC Air Conditioning. It has the "Coffee Can" inside the left front fender
To laugh at men of sense is the privilege of fools.
Old 10-22-2000, 01:41 AM
Tim642957's Avatar
Tim642957 Tim642957 is offline
My 64 tripower GP was converted from vacuum operated to mechanical linkage many years before I bought it. When I bought it, the vacuum operated trunk release used a late model looking plastic container as a vacuum reserve. I don't think this is the correct type vacuum reserve container. It was mounted on the inner fender just behind the headlights on the passenger side of the car. I replaced it with a coffee can type container found in a junkyard. Would this container be the correct type and also be in the correct location? Any information appreciated.
Grand Prix - a world class athlete in a tuxedo
1964 Grand Prix
1966 Bonneville Brougham
1980 Trans Am - original owner
